| Forum topic by Ric2L | posted 406 days ago | 3104 views | 1 time favorited | 14 replies | ![]() |
406 days ago |
Hi all, this is my first post on this forum, I hope this question hasn’t been asked too much, so here goes. I just got done building a pair of speaker cabinets that have Sapele Pommele veneer on them. I started finishing them with Watco Danish Oil wet sanded with 320 to fill the grain, waited over night than applied a second coat of watco, which i will let dry till tomorrow, then #0000 steel wool and a couple more coats of watco & steel wool over the next several days. 3 or 4 coats al togeather. Now, when the watco is wet the grain really pops, however as the finish dries I loose the wow factor of the grain. So, what would you suggest to put over the watco to achieve a permanent wet look. Here are a couple of pics with the second coat of watco applied. |
14 replies so far
#1 posted 406 days ago |
A couple coats of semi gloss finish would help. I haven’t used it, but I understand that water based is the clearest. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#2 posted 406 days ago |
What about some plain old shellac? Compatible w/ the oil, easily refreshed if needed, can be wiped on. No brainer. -- bill@magraphics.us |
#3 posted 406 days ago |
I put oil-based polyurethane over a walnut desk I refinished 2 years ago and it still looks perfect. I chose poly b/c I didn’t think lacquer would hold up to my daily desk abuse (mouse directly on top and sliding keyboards and camera equipment all over it). -- "Well, at least we can still use it as firewood... maybe." - Doss |
#4 posted 406 days ago |
As long as the Watco is cured (takes 30 days or so) you can use Poly finishes tend to be a bit cloudy. This is a nuanced thing to |
#5 posted 406 days ago |
Hi!, Have you posted any details of your speaker build? I’m going to have a go at building a set too. Any extra info would be a great help. Thanks! |
#6 posted 406 days ago |
Thanks for the reply’s guys, I definatly want the grain to pop like it does when the watco is still wet, is it possible to get this result with shellac? I’d like to use laquer, but I aassume that I would have to spray it on and will be afraid of runs!!! A wipe on laquer would be ideal. As far details on the build, the origional desige is from Paul Carmody called “Overnight Sensation MTM” his sight is here http://sites.google.com/site/undefinition/overnightsensationmtm, The cabinets were altered by Mark Toy, who gave me permission to copy his design, His build post is http://techtalk.parts-express.com/showthread.php?t=220137 |
#7 posted 406 days ago |
Super-blonde shellac is used on many of the finest guitars. That’s There is something to be said for taking the work to an experienced |
#8 posted 406 days ago |
If you feel you will need to repair the clear coat Lacquer would be a good Choice (they sell it in rattle cans) but wipe poly will be more durable. I believe 30 days might be a safe time to top coat but I have put a top coat on watco within a few days just make sure the watco’s dry .It has a lot to due with how much humidity you have the air and how warm it is were your letting the wood dry -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 406 days ago |
Solvent lacquer, sprayed or from a rattlecan; or gloss waterborne poly if brushed. A one week cure on the Watco is enough. -- Clint Searl.............We deserve what we tolerate |
#10 posted 406 days ago |
My favorite finish for sapele is Waterlox. It can give you the wow factor you are looking for. I have a sapele AV cabinet in the projects section that shows what it looks like. |
#11 posted 406 days ago |
Hi again, Just checked out your speaker build and guess what—you’re using a Ryobi BT3000! Yesterday I cleaned out my storage room and I found my BT3000 which I bought brand new more than 20 years ago. I’ve never had the spare time to use it until now. I’m building a mobile workstation for it so I can use it to make stuff (boxes, art frames, whatever) for sale. Any opinions on the BT3000? Thanks again. |
#12 posted 406 days ago |
Waterlox sounds promissing, will have to check it out. your AV cabinet is beautiful |
#13 posted 404 days ago |
shellac is easy to apply and will make it look wet. not the most durable for scratch resistance but super easy to refinish because shellac melts together so instead of separate layers you’ll have one continuous thick layer. polyurethane, or arm r seal |
#14 posted 404 days ago |
Well after alot of research and suggestions I believe I’m going to go with Arm-R-Seal, it seems to have what I’m looking for in a finish. It wipes on, is self leveling, gives a clear wet look, comes in saatin, semi glosss and gloss, and is very protective. Thanks for the ideas guys, much appreciated |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3548 |
15776 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
