Finishing plain old 2x8's for son's bed
Forum topic by baniels posted 04-10-2012 04:55 PM 2826 views 0 times favorited 6 replies Add to Favorites Watch
View baniels's profile
baniels
13 posts in 2992 days
04-10-2012 04:55 PM
Topic tags/keywords: bed 2x8 finish
Hello folks,
I am completing a bed for my 3 year old. He’s too big for his crib. The bed is nothing special to look at. A simple platform bed for a double mattress with no box spring. Apart from the legs, the wood exposed will be the 2×8’s that run around the perimeter. I believe they are douglas fir – not 100% on that. Whatever they had in 2×8’s at the local lumber yard.
I am going to do some roundovers on the edges and sand. I’m not sure what to use for a finish yet. I don’t want to paint them – and I don’t want to use anything with nasty chemicals – he will be spending 8 hours a day in close proximity, so I don’t want anything with a toxic offgas.
I used Tried & True Danish oil on the co-sleeper mini bed I built before he was born. That seemed to work nicely on oak. I am testing that oil on a scrap right now – after two coats it feels okay, but looks a little blah. Perhaps more sanding beforehand could help that.
I have toyed with the idea of ebonizing the wood, to make it look a little more interesting. Not sure if I want to do that or not. I have 19 days before his bed needs to be in place on his 3rd birthday.
I guess I’m looking for ideas… It would be nice to darken the wood a bit. It is a bit yellow and I suspect the linseed oil will make it more yellow over time. Would a varnish work? Should I try ebonizing?
Encourage me, discourage me, what would you do?
(slats and center support not shown)
116804 posts in 3449 days
#1 posted 04-10-2012 04:59 PM
You can use General finishes dyestain or some Indian ink to ebonize and then a clear coat.
16272 posts in 4090 days
#2 posted 04-10-2012 05:41 PM
It looks like good old construction grade yellow pine to me. If you want it to be the same color it is now, and not any more yellow, use water-based polyurethane.
If you want to make it darker, it should take any stain color you like…. just test a sample piece first. If you want it really dark, you could always just paint it black. I did that on some pieces for my daughter’s bedroom when she was going through her “black” phase. and the results were pretty good.
View ChrisK's profile
ChrisK
1865 posts in 2953 days
#3 posted 04-10-2012 07:27 PM
You are correct, linseed oil will make the yellow a bit darker. I used toy makers dye for a project and got very bright colors out of SYP.
http://lumberjocks.com/projects/62058
You need to use a clear coat to protect the dye.
-- Chris K
baniels
#4 posted 04-10-2012 07:31 PM
Thanks for the tips, guys. A local “green” building supply has a few options. I bought a sample of a non toxic water based stain in walnut. I’ll give that a try and see how it does.
View Jim Finn's profile
Jim Finn
2592 posts in 2794 days
#5 posted 04-10-2012 10:45 PM
I suggest you use a stain controller before applying any stain. Rather than using a stain, you might consider scorching this wood with a torch and then applying a clear finish over it.
baniels
#6 posted 04-10-2012 10:50 PM
Would Zinsser dewaxed shellac sealcoat be such a stain controller? Have a can of that looking for a use. I really dig your torch idea. I may test that out.
