Wood ID... Need some help
Forum topic by Dan posted 04-10-2012 04:50 PM 1700 views 0 times favorited 16 replies Add to Favorites Watch
View Dan's profile
Dan
3630 posts in 2749 days
04-10-2012 04:50 PM
I got this wood from a pallet that I recently took apart. I am not really sure what kind of wood this is so maybe someone here does.
The wood is very light weight and is probably the lightest weight wood I have ever worked with. I tried smelling the wood but I couldn’t detect even the slightest bit of scent from it.
Judging by the grain and the workability of the wood my guess is its a type of Mahogany. However all the Mahogany that I have worked with before has been much darker in color and has had a scent to it. Its also lighter in weight then the Mahogany I have worked with before.
Any other ideas?
-- Dan - "Collector of Hand Planes"
16 replies so far
View DS's profile
DS
2855 posts in 2289 days
#1 posted 04-10-2012 04:53 PM
Sure looks like Luan Mahogany to me…
(weathered and under tungsten lighting of course.)
116804 posts in 3446 days
#2 posted 04-10-2012 04:56 PM
9752 posts in 3517 days
#3 posted 04-10-2012 05:25 PM
Luan would be my guess as well.
You know those little wood boxes some teas come in? That stuff.
16272 posts in 4087 days
#4 posted 04-10-2012 05:30 PM
It’s palletwood. Comes from the pallet tree, of course.
View DaddyZ's profile
DaddyZ
2475 posts in 2909 days
#5 posted 04-10-2012 05:32 PM
Dan
Looks similar to some I found also I believe it’s Mulberry, also looks similar to a hickory(pecan)
View Dan's profile
Dan
#6 posted 04-10-2012 05:38 PM
I checked out Luan and Luan appears to be what they call plywood that is made of up different types of lower grade mahogany. I saw a list of like a dozen types of Mahogany that can be found in Luan plywood.
I do believe its a type of Mahogany. I guess its not really important exactly what type it is.
View Brandon's profile
Brandon
4152 posts in 2820 days
#7 posted 04-10-2012 05:45 PM
Yeah, I often see cigar boxes made o this stuff.
-- "hold fast to that which is good"
View Dan's profile
Dan
#8 posted 04-10-2012 05:55 PM
The whole pallet I took apart was made of this wood so I have a decent little stack of it. It will be perfect for small boxes.
View DustyPockets's profile
DustyPockets
2 posts in 2106 days
#9 posted 04-10-2012 06:05 PM
Sure looks like Balsa to me….....where did the pallet come from?
View jusfine's profile
jusfine
2422 posts in 2795 days
#10 posted 04-10-2012 06:16 PM
I have similar material that came off off Japanese pallets from Toyota headliners, beautiful to work with. Guess it’s abundant like poplar here.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Dan's profile
Dan
#11 posted 04-10-2012 06:18 PM
I checked into Balsa wood and this could very well be Balsa. I read that Balsa wood is very light weight so there is a good chance thats what it is.
I don’t know where the pallet originally came from but I got it here in west Michigan. It could have come from anywhere though.
View Sarit's profile
Sarit
549 posts in 3008 days
#12 posted 04-10-2012 07:28 PM
You can calculate the density and compare it w/ the woods known here: http://www.engineeringtoolbox.com/wood-density-d_40.html
Measure the weight and length, width, and thickness in inches of one of the pieces. Then do
(weight in lbs) x 1728 / (length x width x thickness)
This gives you the density in lbs/cu ft to compare with the chart.
View deleteme's profile
deleteme
141 posts in 2475 days
#13 posted 04-10-2012 07:35 PM
Does it make sawdust? Can sweet looking dovetails, dado, routed edges, etc. be cut into it? Was it free? I know now…it’s “Win Wood!” Now how do I get my hands on some of that Win Wood?
View gavinzagreb's profile
gavinzagreb
210 posts in 2188 days
#14 posted 04-10-2012 08:59 PM
I’d say it’s definitely not balsa as it wouldn’t be strong enough for a pallet. Balsa is mainly used for model making.
Looks a lot like rubberwood to me. They do make pallets from rubberwood.
View Roger's profile
Roger
20891 posts in 2673 days
#15 posted 04-10-2012 09:57 PM
@A1Jim: Thnx a bunch for that link. Very kool
