no runners for table saw sled
Forum topic by robbiethewood posted 406 days ago 1370 views 0 times favorited 9 replies Add to Favorites Watch
View robbiethewood's profile
robbiethewood
118 posts in 413 days
406 days ago
Topic tags/keywords: jig tablesaw
hi all i have this table saw its a cheep one the table is tin it all is tin i was looking to make a sled for if but there is no runners it has its Owen cross-cut sled witch is crap so i am looking for ideas from you guys for making something up for it it has a good motor in it and a new blade so i think its worth buying a sheet of ply and doing something whith it
here is some photos of it
THANKS rob
cheep
-- http://robbipowerwoodturner.blogspot.com/
9 replies so far
View oluf's profile
oluf
252 posts in 1207 days
#1 posted 406 days ago
If the sides of the table top are not parallel, add some hardwood strips to the sides and shim them so that you have true parallel sides. Now make a sled with cleats that hang down on each side and ride snug on the strips you added. Square up a front and back fence and you are in business. Take off and store that sliding table.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
robbiethewood
#2 posted 406 days ago
thanks oluf i never tough of using the sides of the table
that makes good sense
View chrisstef's profile (online now)
chrisstef
5250 posts in 1174 days
#3 posted 406 days ago
Or if you dont mind losing a little depth of your cut you can make an entirely new top out of ply or mdf with a miter slot. Ive seen a lot of old table saws set up like that when the original tables were super small.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View RandyM68's profile
RandyM68
693 posts in 486 days
#4 posted 406 days ago
I believe this is what Oluf is talking about. If it fits tight at the edges, it should work o.k.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
87110 posts in 1745 days
#5 posted 406 days ago
I have a student that had the same problem ,I just suggested he take a piece of 3/4 ply and put a couple groves in it like most table saws miter grooves and clamp it to his table saw top and then make a sled to match the grooves, He said it worked like a charm.
robbiethewood
#6 posted 406 days ago
hey thanks randy for the photo
i see what you mean about the edge of the table
so many ideas now witch one is best
View KOVA's profile
KOVA
954 posts in 546 days
#7 posted 406 days ago
http://woodgears.ca/reader/contreras/index.html IN THIS LINK YOU WILL SEE HOW DID THIS SPANISH CARPENTER BUILT THIS SLIDE TABLE ;-)
-- KOVA, EL CARPINTERO DEL PUEBLO https://www.facebook.com/pages/El-Carpintero-Del-Pueblo/148976618479733
robbiethewood
#8 posted 406 days ago
thanks kova wow you put some work in to that project that’s is unverifiable you turned a circler saw into a table saw
well done
View KOVA's profile
KOVA
#9 posted 404 days ago
THANKS FRIEND: BUT THE PICTURE IS OF A CIRCULAR SAW PLACED ON A TABLE, I USE A TABLE SAW AND BETTER IT WORK SURFACE:http://lumberjocks.com/projects/64114
