How to find half of 11/16 the easy way.
Forum topic by RussellAP posted 409 days ago 2291 views 0 times favorited 13 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 457 days
409 days ago
How many times have you had to find the halfway point between some odd numbers?
Here is an easy way to measure the distance between those odd measurements.
Put your tape at one end of the board and simply angle the other end till you get to an easily divisible number. Then mark the half way point, or quarters, or whatever.
Here is an example of a board measuring 2 3/4. Some of you know what half of this is, but you don’t have to know, just slide the end of the tape till the other edge is on three inches.
Like this.
Then mark the 1 1/2 which is now halfway. This works on just about anything you want to divide in two, three, four…..
Olef pointed out that the tape I’m using wouldn’t give the ‘exact’ half way point, but if I didn’t have a camera in my hand I’d have started the tape on the one inch mark, or used a ruler which I usually do when I measure. I don’t like tape measures, the rivets can loosen up and make every measurement you use slightly off. I prefer a metal ruler.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
13 replies so far
View oluf's profile
oluf
252 posts in 1210 days
#1 posted 409 days ago
The way you are holding the tape measure in the picture will not give you the half way poin./ The tab on the end of the tape measure is not as wide as the tape. Which side of the tape are you going to read the 1 1/2 inches on?
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View rhett's profile
rhett
554 posts in 1838 days
#2 posted 409 days ago
View rasp's profile
rasp
74 posts in 429 days
#3 posted 409 days ago
picked up this trick in college, from an elderly fellow that grew up in England, earned his apprenticeship building boats. so many tricks to learn.
RussellAP
#4 posted 409 days ago
oluf, I was not in my shop when I did this. I rarely use tape measures, I prefer a ruler, so yes, it won’t be exactly half with this tape unless you hold the tape on the left side of the line. But you get the point. I would hold the tape at the one inch mark if I didn’t have a camera in one hand, lol.
View sandhill's profile
sandhill
1978 posts in 2094 days
#5 posted 409 days ago
Very slick, I will have to remember this. Thanks
View ducky911's profile
ducky911
163 posts in 960 days
#6 posted 409 days ago
Thanks. Very good trick. Ijust learned that the other day. You can use it to find mult. Spacings also like 3 or four equal spaces..good for dovetail layout. Pretty cool trick.
When getting down in fractions i don’t like below 16th. I bought a digital thickness gage and it reads 11/64..?? Whats that?..is that alittle more than 2/16ths….to much info….we are dealing with wood here.
TopamaxSurvivor
13194 posts in 1846 days
#7 posted 409 days ago
Roy and Norm had to demonstrate that about 15 times before I finally remembered it ;-))
View wee3's profile
wee3
76 posts in 442 days
#8 posted 408 days ago
Yea,thats a good tip,use it alot with steel rule@tape.
-- BiLL @wee3
View Martyroc's profile
Martyroc
2708 posts in 476 days
#9 posted 408 days ago
Nice tip, thanks for the reminder I used that tip years ago and somehow forgot all about it.
-- Martin ....always count the number of fingers you have before, and after using the saw.
View TechRedneck's profile
TechRedneck
636 posts in 1028 days
#10 posted 408 days ago
I just keep a 12” metal center riule in my apron. Use it all the time
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
TechRedneck
#11 posted 408 days ago
I just keep a 12” metal center ruler in my apron. Use it all the time
View Richard's profile
Richard
503 posts in 861 days
#12 posted 408 days ago
ducky911 , 11/64s is time to run it thru the planer one more time for just a skosh bit. and a skosh is a real Tech term. :) I would have to get out my calculator and mess with it for a while to come up with the right answer for that.
View helluvawreck's profile
helluvawreck
10466 posts in 1037 days
#13 posted 407 days ago
The tab on the end of the tape is not necessarily accurate anyways. Just use the 1 inch mark and the 4 inch mark and use the middle mark (2-1/2 in.). Better yet use a good 6 inch machinist ruler instead.
helluvawreck
https://woodworkingexpo.wordpress.com
