| Forum topic by Seer | posted 73 days ago | 665 views | 0 times favorited | 13 replies | ![]() |
73 days ago |
I rent the house I live in and I also live in Phoenix, Az where it is too hot to work in the summer. I am looking at either an Evaporitive cooler I saw at home depot (it is a small roll around unit) or getting an AC unit that mounts in a window and putting it on a cart to cool my shop. Does anyone have any thoughts on this matter or suggestions? |
73 days ago |
The only draw back I could think of to the evaporative cooler, would be the extra humidity you introduce into your shop, ie. rusted tools. -- Tim -- http://tmuli.com |
73 days ago |
Humidity will rust all your tools out using a cooler. I use an AC unit in the window. Cools and gets rid of any humidity which is a concern in this part of Texas. Not so much in AZ. Putting an AC unit on a cart doesn’t do you any good. You need to stick the hot end outside. Just buy a pleted filter and add it to the front of the AC to keep dust out. I have to replace my filter about once a week. -- Gary, East TX -- The longest journey begins with a single step. |
73 days ago |
You need one of these. They just need to exhaust to the outside via a dryer-duct-like tube. -- Charlie M. "Woodworking - patience = firewood" |
73 days ago |
Thanks I like that I have ideas to go by now |
72 days ago |
I do have large trees that help shade the roof, but I live in Texas where we’ve hit 100 degrees already. I work in the detached garage with the door up. I have three fans that I picked up off the curb around town that were thrown away for other reasons that they didn’t work (noisy, broken base, etc) I think it’s bearable as long as the air is moving and drink plenty of water. They’re also a low-tech dust system blowing dust out the door. -- Paul, Texas |
72 days ago |
For your dust collector you will want to buy a .5 micron filter. It will be a necessity for you to keep healthy. An ordinary bag filter will put you in the hospital and give you serious lung problems. -- Oldworld, Fair Oaks, Ca |
72 days ago |
air conditioning gets clogged with dust and the other causes rust.. can I recommend an iced cold drink (no alcohol near the tools) and if that doesn’t work, Ice down the pants. Good luck and stay cool -- making sawdust.... |
70 days ago |
I have central air in my shop. Have to change filters a lot. I just had the freon charge just minutes ago. It was 88 in there today. I was dripping sweat all over my project. It is cooling down as we speak! YES! -- JB |
69 days ago |
Jerry: I live in the desert of Southern California a few years I installed a window evaporative cooler that I bought at Home Depot. It is a 450 CFM unit made for window mount, but I cut a hole in the wall. The unit I bought has only 12 inches or so that it sticks outside the shop. It works great. My shop is cooler than my house in the summertime. One tip would to mount the cooler so that it is in the shade most of the time. That is a big help. I think Phoenix is like the area I live in. We do not get rust. The relative humidity was 10% yesterday. Also, unless you live in a dry climate the evaporative cooler will not work. Phoenix, Arizona you should be OK. -- Bob Clark, Tool Collector and Sawdust Maker |
69 days ago |
The big problem with portable air units is the moisture collection tank. I used different models as back up in data centers. They contain a plastic tank that catch the water and will fill up a couple times a day so it becomes agravating to have to empty it so frequently. A window unit on a portable cart will have the same problem. You would have to come up with a way to catch and drain the water outside. -- Dennis... www.closetdreams.com |
69 days ago |
My shop is 1/2 the basement of my house. Humidity can be a problem in Georgia. I run two 10 tonne AC units with ceiling fans and it works out pretty good. You could hang meat in here. There are 2 attic exhaust fans on thermostats to clear that space. You guys probably wouldn’t want the electric bill, but I moved down here from Iowa, and at times paid comparable prices for heat up there. bbqKing -- bbqKing, Lawrenceville |
66 days ago |
The problem with the window unit on the cart is the heat the unit will generate, tried that once in my auto shop, mounted a window unit in interior wall, made shop hot from heat of electric motor. If you use ac mount to exterior wall in shaded area if possible, or build an awning over it, any shade will help to prolong life of unit. -- Pretzel L8agn |
65 days ago |
I live in Chandler, AZ and have a thing called A Cool Door that works great but may not be a good fit for your rental situation. It has an evaporative unit built into a security door (neighborhood restrictions don’t allow swamp coolers on the outside but do allow security doors). There is an attic fan that pulls outside air through the door and exhausts it through the ceiling into the attic. Last week when it was 111 outside, it was 85 in the garage, a 26 degree drop… not bad. I can work fine at 85. Also, because it is so dry here, I don’t have problems with the humidity building up. Just take normal precautions to prevent rusted tools. The bad news is that you have to mount the fan in the ceiling and have a side door to the outside. Also it costs a bit over $1k, still a bunch cheaper than A/C and a whole bunch cheaper to run. Good luck—- Garageshop c |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1126 |
1508 |
103 |
295 |
95 |
Woodworking Trade & Swap
204 |
Coffee Lounge
818 |
LumberJocks.com Site Feedback
254 |
