I need router dimensions
Forum topic by MrRon posted 04-09-2012 05:06 PM 1173 views 0 times favorited 2 replies Add to Favorites Watch
View MrRon's profile
MrRon
4560 posts in 3113 days
04-09-2012 05:06 PM
I’m designing a CNC router and need the dimensions for the following routers: Porter Cable 690VS and Bosch 1617 VS. I need just the dimensions of the motor, without the base. Thank you.
2 replies so far
View BlankMan's profile
BlankMan
1490 posts in 3223 days
#1 posted 04-10-2012 01:06 PM
I can give you dimensions from s 690LR not a 690LRVS if that helps.
-- -Curt, Milwaukee, WI
MrRon
#2 posted 04-10-2012 03:08 PM
Yes; that will work. I’m trying to optomize the design of the support for the router. I’m not sure which router I will use until I can compare the dimensions of each.
