Mortise and Tenon via a router.
Forum topic by pashley posted 167 days ago 420 views 0 times favorited 2 replies Add to Favorites
View pashley's profile
pashley
388 posts in 254 days
167 days ago
Topic tags/keywords: tenon mortise router
I suppose THE way to make mortise and tenon is to use a tablesaw tenon jig and a mortising machine, but without that, how about the same thing via a router? It’s easy enough to use a plunge router to make a mortise, but that of course leaves you with an elongated oval. So how to make an elongated oval tenon easily?
One thought I just had – when using the plunge router to make the mortise, use a 1/4” straight bit, which should give you pretty small corner radii – and then just cut a tenon per usual on the tablesaw, and round the corners over manually via sandpaper or file.
-- -Be Blessed!, Patrick
View GaryK's profile
GaryK
8558 posts in 525 days
167 days ago
Well, you could either use a chisel to square the corners of the mortise or a chisel to round off the corners of the tenons.
View Rob 's profile
Rob
101 posts in 204 days
167 days ago
I’m in the middle of building my first mortise and tenoned piece and have done 36 joints so far. I was thinking of going the plunge router route; made a nice jig and all; but in practise I found I kept overshooting the ends and the cut just wasn’t good enough (too much play in the router I think). So I decided to use a forstner bit on the drill press with a fence to guide the hole in line, then I cleaned up the rest with a chisel. Seems to work better for me.
Bookmark And Share This Page
