What grit sandpapers do you use in cabinets and built ins?
Forum topic by noone posted 04-08-2012 08:07 PM 912 views 0 times favorited 4 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2389 days
04-08-2012 08:07 PM
What grit sandpapers do you use in cabinets and built ins? I have just finished some cabinets and was wondering what finish grit I should use to prep them for paint.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2472 days
#1 posted 04-08-2012 08:10 PM
depends on the density of the wood and the type finish.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
TCCcabinetmaker
#2 posted 04-08-2012 08:11 PM
usual grits for dense hardwoods 80 100 120, 150
softer woods I may start at 100 or even 120.
noone
#3 posted 04-08-2012 08:29 PM
It’s birch ply with poplar face frames.
TCCcabinetmaker
#4 posted 04-08-2012 08:36 PM
120 should suffice, sand the birch quickly don’t spend too much time on it or you will “burn” the plywood.
poplar usually cleans up fairly easily with 120. if you find your progress is slower than desired drop down to 100, then go back to 120. you may want to go higher, IF, you are staining but that’s a judgement call.
