All-In-One Contractor Clamp from HF
Forum topic by Jim Crockett (USN Retired) posted 06-17-2008 03:38 AM 1595 views 0 times favorited 7 replies Add to Favorites Watch
View Jim Crockett (USN Retired)'s profile
852 posts in 3855 days
06-17-2008 03:38 AM
Topic tags/keywords: clamp
Does anyone know anything about this clamp? It looks very similar to the one Amazon is selling for $60.00 (some slight differences in the t-track edges), but it is selling at HF for $24.99. The HF one is 50” while the Amazon one (from Emerson Tools) is 54”. At $24.99, this would be quite a deal if it is pretty much the same.
Jim
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
7 replies so far
View GMman's profile
GMman
3902 posts in 3819 days
#1 posted 06-17-2008 03:40 AM
Can you post a photo of it
#2 posted 06-17-2008 04:00 AM
I can try.
All-In-One Clamp
Well, how about that – it worked!!!
Jim
teenagewoodworker
2727 posts in 3890 days
#3 posted 06-17-2008 04:05 AM
probably the difference is quality. i would think (just what i would think) is that the hf one would have less clamping strength and less overall strength while the amazon one would probably be of better quality. just thinking though someone else might have a better argument the other way.
GMman
#4 posted 06-17-2008 04:11 AM
I would say if you are a hobby woodworker and the only one using it I would go with the cheapest one, a contractor with everybody working with it well you know what I mean…I have tools that are not expensive and I take care of them and they last as long as an expensive one
View Slacker's profile
Slacker
178 posts in 3823 days
#5 posted 06-17-2008 04:50 AM
I got that clamp, and it works pretty good, but then I made a jig that allows you to use a circular saw or router and you just lay it on the mark line. The jig is much better than the product, because you have to measure from the cutting edge to the fence.
-- Adapt, improvise, overcome
View Loren's profile
10477 posts in 3770 days
#6 posted 06-17-2008 06:31 PM
I have something similar to this… clamp-n-tool guide I think.
I mostly used it as a drill press fence. Worked great for that.
16276 posts in 4340 days
#7 posted 06-17-2008 06:42 PM
I have the same exact one also. It works pretty well…I use it quite a bit.
