Rip cut binds on table saw, best solution?
Forum topic by AffineCreations posted 04-08-2012 06:07 PM 6033 views 0 times favorited 16 replies Add to Favorites Watch
View AffineCreations's profile
AffineCreations
28 posts in 2285 days
04-08-2012 06:07 PM
Ripping a 24” long, 7” wide, 1” thick piece of cherry on my table saw. Cut is 3” in. About 1/3 way through the cut, board starts to bind and quickly the board wants a lot of force to move forward. I carefully reach over and power down the saw.
First off: I am thankful I have the riving knife in place, along with the anti-kickback pawls. Board did stay on the table and I still have all my fingers.
I unplugged the saw and wrestled the board free of the blade. Inspection showed the board had been under tension and closed around the kerf, hence the binding. I will point out the board was planed on the table down face and jointed on the edge against the fence.
I proceeded to start the cut again, letting the blade redo the part of the cut that had slightly closed up. The rest of the cut went fine, with no extra force needed to finish. The other three similarly cut boards ripped without incident.
Question: first time something like this has happened to me. I am new to working from rough-cut lumber and dimensioning it myself. Did I proceed in the safest fashion, or is there a preferred method to deal with rip cuts that bind?
-- - Nicholas, Silver Spring, MD http://AffineCreations.com
16 replies so far
View waho6o9's profile
waho6o9
8207 posts in 2604 days
#1 posted 04-08-2012 06:10 PM
Use a band saw, another fine tip expressed on LJ. I learned the hard way as well on Zebrawood, Oops.
16275 posts in 4245 days
#2 posted 04-08-2012 06:11 PM
If there is a better way, I’m not aware of it. As far as I know, you did everything right.
View Loren's profile
10476 posts in 3675 days
#3 posted 04-08-2012 06:50 PM
Yeah, that happens. Sometimes you can do what you did and
recut the kerf and it will work out. Sometimes you’ll have to
flip the board and cut from the other end. Then sometimes
there is so much tension in the board you cannot safely cut it
on the table saw. Safest practice is to rip solid wood with
a band saw.
View Brit's profile
Brit
7387 posts in 2869 days
#4 posted 04-08-2012 09:22 PM
For a two foot long Cherry board, I’d use a 6tpi rip saw personally. If it starts to close up behind the saw, just stick a wedge in it and carry on.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View stefang's profile
stefang
15881 posts in 3361 days
#5 posted 04-08-2012 10:29 PM
I like to do ripping on my bandsaw. I think It’s safer and a lot more effortless and it also generates less sawdust. a good choice if you have a decent bandsaw.
I think rip cutting will wear down a sharp table saw blade very fast and it also puts quite a strain on the motor, especially with the lower hp saws mostly found in hobby wood shops.
View RussellAP's profile
RussellAP
3104 posts in 2313 days
#6 posted 04-08-2012 11:06 PM
I work primarily with pine so I just push it harder when that happens, but if it were hardwood, I’d knee the switch and start over too. Heck, with pine you can cut a curve with a TS if you want.
View knotscott's profile
knotscott
8057 posts in 3402 days
#7 posted 04-09-2012 01:17 AM
Any chance that your blade is a bit too thin for the riving knife? What saw and blade are you using?
View gfadvm's profile
gfadvm
14940 posts in 2717 days
#8 posted 04-09-2012 02:14 AM
You did the safe thing and that’s the most important part. After I stopped the saw I would drive a wedge in the sawed kerf and have another go at it, replacing the wedge as necessary.
View bondogaposis's profile
bondogaposis
4767 posts in 2378 days
#9 posted 04-09-2012 02:34 AM
I use Brit’s method.
-- Bondo Gaposis
View NiteWalker's profile
NiteWalker
2737 posts in 2604 days
#10 posted 04-09-2012 06:43 AM
What gfadvm said.
View Manitario's profile
Manitario
2630 posts in 2910 days
#11 posted 04-09-2012 07:24 AM
Happens to me all the time with rough sawn lumber. You did the right thing. Just drive a wedge (or a large screwdriver!) into the kerf and continue on.
View ShipWreck's profile
ShipWreck
557 posts in 3779 days
#12 posted 04-09-2012 10:18 AM
You did everything that I would have done with stopping the cut AffineCreations. I have had binding many times before the wood safely reached the riving knife. It usually was from the wood closing past the blade kerf, or operator error on my part.
AffineCreations
#13 posted 04-09-2012 11:56 PM
Thanks everyone for the feedback. Nice to get the impression my sense for how to deal safely with a table saw is pretty good. Though I love that tool, it always scares me. I like the idea of using the bandsaw to rip cut rough lumber. Will definitely try that next time.
View Paul Tomlinson's profile
Paul Tomlinson
1 post in 52 days
#14 posted 05-01-2018 04:56 PM
You did everything right!
I also keep small (kerf sized) finely tapered hardwood wedges close at hand to tap in after turning off the saw.
-- Those without a sense of humor are at the mercy of the rest of us - Vince Sabio (Jokelist Admin)
View clin's profile
clin
853 posts in 1023 days
#15 posted 05-01-2018 11:16 PM
Paul, welcome to the forum!
But you have resurrected a 6 year old thread (necro-posted). Not sure why this seems to happen with new members. But what is about to happen is a bunch of people are going to start chiming in, only reading the original post (OP) and not noticing the date is 6 years old. They will then spend effort answering his question. Of course the answers are still valid, but not very timely.
And I’m not trying to scold you. We’re easy going around here. Welcome and I look forward to your continuing contributions.
-- Clin
