Contractor Table Saw Dust Collection
Forum topic by hhhopks posted 04-08-2012 03:42 PM 36010 views 2 times favorited 68 replies Add to Favorites Watch
View hhhopks's profile
hhhopks
651 posts in 2405 days
04-08-2012 03:42 PM
Topic tags/keywords: dust collection contractor table saw tablesaw table saw question suggestion tip ideas
Anyone out there has any suggestion for dust collection for a contractor style table saw?
I recently have purchased a used TS and is in the process of getting it tuned. It will sit in my garage. I figured controlling the dust will be easier on me, health wise and will also reduce my clean up effort too.
Dust just goes everywhere.
Just like to see what everyone else is doing. Hopefully there are some good tips out there.
-- I'll be a woodworker when I grow up. HHHOPKS
68 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3096 days
#1 posted 04-08-2012 03:46 PM
One, pretty effective, method would be to build a cabinet to replace the legs, and have a dust collection chamber in the cabinet. The chamber can easily be connected to a DC system thru a blast gate.
A second option would be one of the aftermarket bags that can be attached inside the legs. No DC, but it at least contains the sawdust.
View knotscott's profile
knotscott
8057 posts in 3403 days
#2 posted 04-08-2012 03:52 PM
Something like this from Eric_S' blog is fairly simple:
You could also block off the back like a member of Woodnet did:
hhhopks
#3 posted 04-08-2012 04:04 PM
SawKerf, I have tried the bag method on my previous TS. It was OK to collect the big stuff but the fine dust get everywhere.
The cabinet approach, ???? I have to think about that.
Scott, Thanks for the pictures.
The intermediate mounting table with chute looks good.
I would think the chut (the box part) will need an opening to clear up jams every once in awhile.
I was toying with the idea closing out the rear too. How do you still allow the blade to tilt?
How critical is it to have all the opening sealed? There are still openings on the front where the tilt gause and height adjust srews are.
View taoist's profile
taoist
124 posts in 2519 days
#4 posted 04-08-2012 04:36 PM
I have a Delta contractors saw and have a dust collector hooked up to it. The saw came with a sloped pan on the bottom of the saw with a 4” hook up. It works fairly well. I tried to block off the back of the saw (motor/belt area) but when it is blocked off a lot of sawdust comes up on top of the table. I just use it the way it came so it’s not perfect but a lot better than the bag on the bottom or just letting it fall. It’s my opinion that the only truly complete dust collection has to have below and above the table dust collection.
View Roger's profile
Roger
20929 posts in 2832 days
#5 posted 04-08-2012 04:46 PM
This is what the underside of my old ‘50’s Craftsman looks like, and it works pretty well, but I need to add some to the top, at the blade, one o these days.
View Bill White's profile
Bill White
4950 posts in 3988 days
#6 posted 04-08-2012 04:47 PM
Get the shroud that will fit the bottom, and don’t completely black the rear. It cut WAY down on the air flow. Mine is partially blocked with a removeable panel. Take it off when tilting blade. I’m using the HF DC with good results except for above-the-table collection.
Bill
-- bill@magraphics.us
View Tom148's profile
Tom148
39 posts in 2292 days
#7 posted 04-08-2012 04:49 PM
Sears made a dust kit 133299510. Some of the parts are still available but maybe not all. The re may be a replacement part # but I know the exploded view is available online at searsparts.com. I have this kit on my 113….Craftsman saw and it works ver well. I think you could easily replicate it from some Luna or plastic sheet, some brads nd some glue. You can get a vacuum port at any supply store.
Good luck!
-- Tom
Roger
#8 posted 04-08-2012 05:07 PM
Actually, mine has one o those, maybe 12×12 or so flat plastic dust collection pieces with a 4” hole in it. It fit perfectly, and the 1lb coffee can was just an extention because the port wasn’t long enough, and I couldn’t get the hose to stay on. I also have a cardboard piece with cut-outs for the belt, motor, etc that I move when I tilt the blade. It’s jury-rigged, but, hey, it works.. lol Dust needs to be in a collector, not our lungs
knotscott
#9 posted 04-08-2012 05:29 PM
You’d need to either remove the back panel, or build one with a slot for the motor to tilt.
View zzzzdoc's profile
zzzzdoc
550 posts in 3031 days
#10 posted 04-08-2012 07:48 PM
Building a box does work fairly well. It is also important to seal off most of the back of the contractors saw. The side gaps provide enough air flow. Also need to block off the front where the crank comes out.
Here’s a link from my cabinet I built for my SawStop that shows blocking off the back of the cabinet. The pieces need to be removable for when you miter the blade. http://lumberjocks.com/comments/850983
I found it important to keep the dust box under the saw as small as possible. A sloping board improved things immensely.
Dust collection box
If you want to take this route, my blog has a lot of details in doing this for a SawStop. I’m sure other contractors saw are pretty similar to do this with:
SawStop Cabinet Blog
That refrigerator magnet material (can be obtained from a sign shop) can be used to seal off the front of the saw.
-- Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
View Mainiac Matt 's profile
Mainiac Matt
8090 posts in 2356 days
#11 posted 04-08-2012 11:16 PM
I have the exact same TS and have the factory adaptor kit mentioned by Tom. It has a 2.5” hook up for a shop vac.
I recently modified it for hooking up a 4” line with no reducer and it is working well.
As mentioned, above the blade it gets messy, so I use the factory blade guard most of the time.
IMO these are pretty darn good table saws and can be dialed in quite well. There is an alignment aide that you can mount on the trunions that gets very good reviews. I don’t have it,but wish I did, as adjusting the trunnions to get the blade parallel to the slot can be quite the chore if you have to tap it into position. You’ll get it just right, only to have it shift when you tighten up the bolts.
I have the exact same fence as well and really like it….as it has no discernable flex when adjusted correctly and locked down…..
Enjoy your new saw!
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
Mainiac Matt
#12 posted 04-08-2012 11:53 PM
this is the link for the Pals
Here’s a couple snaps of the modified factory DC adaptor…
it has a 2.5” hookup on the back side (which I plugged)
and a removeable clean out door on the front side, to which I attached a 4” hook up.
hhhopks
#13 posted 04-09-2012 04:05 PM
Thanks for the suggestions.
I will give it shot. the drop down box concept appeals to me.
I will add a back plate to cover the rear openings.
View History's profile
History
399 posts in 2009 days
#14 posted 12-22-2012 06:10 PM
I have been making these in several different sizes for Contractor’s table saws.
View toolie's profile
toolie
2135 posts in 2656 days
#15 posted 12-22-2012 08:50 PM
weren’t those sold by a major retailer for a while, like penn state industries or mlcs WW?
showing 1 through 15 of 68 replies
