What finish for pistol grips?
Forum topic by pariswoodworking posted 04-08-2012 03:15 AM 13947 views 1 time favorited 19 replies Add to Favorites Watch
View pariswoodworking's profile
pariswoodworking
386 posts in 2391 days
04-08-2012 03:15 AM
I just started making pistol grips, and was wondering what the best finish for them would be? Basically, I want them to be glossy, tough, and resist dirt and grime that may come into contact with them. Would Tung oil be good for this, or should I stick to lacquer or poly? Is there something else that works well?
Thanks
-- Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. -- Albert Einstein
19 replies so far
View RandyM68's profile
RandyM68
693 posts in 2224 days
#1 posted 04-08-2012 12:11 PM
I think laquer scuffs too easily, and before long you would probably have scratches and chips all over. Poly would be the most durable, but it gives that plastic shine that I don’t really like on a gun, but that is up to you. I refinished a black walnut rifle stock, with linseed oil. It still looks good thirty years later. I haven’t tried tung oil, so I don’t know , but it would probably work pretty well.
-- I can explain it to you, but I can't understand it for you. I'm sorry,thanks.
View Mainiac Matt 's profile
Mainiac Matt
7665 posts in 2235 days
#2 posted 04-08-2012 12:57 PM
I’d use polyurethane, because you are sure to get oil and solvent on them, and cured poly is tough stough.
-- Pine is fine, but Oak's no joke!
View Fuzzy's profile
Fuzzy
298 posts in 3895 days
#3 posted 04-08-2012 04:39 PM
Something that works great, but you seldom ever hear about … use a vacuum chamber hooked up to a vacuum pump to pull the finish deep into the pores of the wood … leave ;em in for a few days then let them cure for a few weeks before buffing & polishing … works GREAT on small pieces like this.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
pariswoodworking
#4 posted 04-08-2012 05:40 PM
I don’t have anything I could uses as a vacuum chamber, but I will remember that, and try it in the future. Thanks.
I tried (spray) poly before I tried lacquer, but it would not dry. The wood is Desert Ironwood Burl. Is that normal? Would sealing the wood with shellac work?
View bake's profile
bake
384 posts in 3584 days
#5 posted 04-08-2012 06:34 PM
Use CA glue it makes a great finish and wears like iron.
-- I love the smell of Home Depot in the morning, it smells like.......carpentry. Bake, Bar Lazy U Woodworks, Lehi,UT.
View Clint Searl's profile
Clint Searl
1533 posts in 2268 days
#6 posted 04-08-2012 07:13 PM
Lin-Speed Gunstock Oil
View HalDougherty's profile
HalDougherty
1820 posts in 3144 days
#7 posted 04-08-2012 08:43 PM
I carve gunstocks all the time and start my finish with pure tung oil cut 50% with mineral spirits. After sever coats wet sanded into the wood with extra fine stainless steel wool, I mix 50% exterior spar varnish with the 50-50 mixture of tung oil and apply thin coats with steel wool, wipe dry after 5 minutes of rubbing and wait 24 hours for the next coat. Ironwood will polish hard enough without any finish, but I like the way a hand rubbed oil finish looks. A Lin-Speed finish looks the same, it just costs a lot more per oz to buy. If the finish ever gets scratched up, just a quick sanding and rub in a few coats of your varnish, tung oil mixture and it looks great again. Watco Danish oil finish is about the same as the mixture I use. You can pick up a can at Lowes or Home Depot. Linseed oil never dries to a hard finish, so I avoid it.
-- Hal, Tennessee http://www.first285.com
pariswoodworking
#8 posted 04-08-2012 10:16 PM
@ bake—- I’m about out of CA glue, so that won’t be possible right now, thanks though. What kind do you use? Thin, med, or thick? Also, do you mix it with something like linseed oil, or just use pure CA?
@ Clint—- I’ll have to look into the lin-speed. Thanks.
@ Hal—- Thanks for the advice. Do you use 000 or 0000 Steel Wool? Also, how glossy does that come out?
pariswoodworking
#9 posted 04-09-2012 02:32 AM
Ok, I tried the (minwax spray) poly finish earlier (over shellac) and it is still wet (sort of). It has been about 6-8 hours since I put it one, and it’s still really soft. It’s slightly tacky, but not really wet. Just really soft. What should I do? Should I just leave it and see if it dries, or should I do something else?
View bake's profile
bake
#10 posted 04-09-2012 03:16 PM
I use the thick CA. Don’t mix it with anything use several thin even coats then sand with 1200-12000 grit.
it will give a high polish.
Hals finish is real nice use 0000 and it will come out a beautiful satin.
View ParksArt's profile
ParksArt
26 posts in 2148 days
#11 posted 04-09-2012 03:25 PM
You might give TruOil a shot (ha. get it? shot?.. boo) Anyway, it’s a gunstock finish. It looks great and dries fairly quickly for more coats.
View Doss's profile
Doss
779 posts in 2171 days
#12 posted 04-09-2012 03:56 PM
Type in “gun stock oil” or “gun stock finishing” into Google and you will find a whole slew of products to use.
I’d stick to something that acts more like an oil (penetrating) than a film (sitting on top of).
If the finish starts coming off, they’re either going to have to send in the grips/stock (we call wood on a gun furniture) or buy a new one. That also means they are less likely to buy another set from you.
I like my “furniture” to look as flat or matte as possible. Personal preference.
-- "Well, at least we can still use it as firewood... maybe." - Doss
pariswoodworking
#13 posted 04-11-2012 02:17 AM
Thanks for the advice everyone. I founds something that works. Water based poly. Any advice on how to get the last coat to turn out smooth, and polished?
View Doss's profile
Doss
#14 posted 04-11-2012 03:05 AM
I would say use wipe-on poly, but I’m not sure if it’ll be compatible with whatever type of water-based poly you’re using. It could be; I just don’t know for sure.
Load up an old T-shirt with the stuff and wipe it on. Make the shirt (or whatever you use) is lint-free and that you sanded your previous coats down with at least 600 grit (for the final coat to go on smooth).
Lots of thin coats that are properly prepped between each coat goes a long ways to a great finish.
pariswoodworking
#15 posted 04-11-2012 04:37 AM
I’ve been brushing it on, with a 800 grit sanding between each coat, but I’ll start wiping it one and see how it turns out.
Thanks
