How to get Powermatic PM1800 into basement?
Forum topic by Jeff Stroomer posted 407 days ago 957 views 0 times favorited 19 replies Add to Favorites Watch
View Jeff Stroomer's profile
Jeff Stroomer
2 posts in 407 days
407 days ago
Topic tags/keywords: bandsaw question
I am thinking of buying a Powermatic PM1800 bandsaw, but how in the world can I get it into my basement workshop? It weighs more than 800 lbs, so I’m not going to round up a couple buddies and heft it down there.
My basement is a walk-out with a sliding glass door, so it might be possible to get it to the edge of the basement using a forklift. But then what? I could perhaps remove the table and the motor, but it seems like the remaining bits would be plenty heavy.
Surely someone else has faced this problem – what’s the answer? This saw costs $4,700, so it also seems like Powermatic might have some suggestions.
-- Jeff Stroomer
19 replies so far
View Scot's profile
Scot
344 posts in 1562 days
#1 posted 407 days ago
Furniture movers from HF worked great moveing the heavy tools into my shop
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View SCOTSMAN's profile
SCOTSMAN
4308 posts in 1751 days
#2 posted 407 days ago
Listen I have a very heavy bandsaw that I bought including delivery direct into situ in my shop.the men had to manouvere it up two flights of steps up the grass and up my front path before dropping it low on one side and tilting it it into situ on the shop floor.Please remember, it can be done. Have fun Alistair
View Loren's profile
4873 posts in 1814 days
#3 posted 407 days ago
Remove any parts that stick out. Fix 4×4 skids to the
edge and move it on it’s side. You can slide it down stairs
on the skids or put a couple of skateboard dollies under
it and roll in in the door.
Once you get the motor and table of you’ll only be
dealing with about 600 lbs. which is about 1.5 times
the weight of a 10” cabinet saw. Three guys can
move something that heavy without too much trouble.
View Bluepine38's profile
Bluepine38
2088 posts in 1252 days
#4 posted 407 days ago
Are you buying this new or used, if it is new, contact the seller and ask how it is shipped. It may come in
several easily moved pieces. If it is all bolted together, it looks like the easiest way would be to lay it
flat on that solid back post and use two or three heavy duty furniture dollys. You will need 3 or 4 people
in fairly good shape to move it, and safely tilt it.
-- As ever, Gus-the 74 yr young apprentice carpenter
View DIYaholic's profile
DIYaholic
7277 posts in 841 days
#5 posted 406 days ago
Disassemble, move ONE piece at a time & then reassemble. Lol.
It would work though.
-- Randy-- I may not be good...but I am slow!
View Grandpa's profile
Grandpa
2380 posts in 842 days
#6 posted 406 days ago
My son and I moved an 800 lb safe. We got a heavy duty dolly and got it strapped on. This dolly has wheels (castors I believe) under the handle that would fold out of the handle that would flat out of the way or lock down to hold the handle and the optimum angle. We moved it about 50 feet and we were plenty tired at the end of the move.
View derosa's profile (online now)
derosa
1468 posts in 1002 days
#7 posted 406 days ago
Break it down and use a hand truck. The motor, the table, the base, and the top will all be separate pieces. With a hand truck up to 300lbs isn’t too hard if you don’t have to navigate more then a step or two.
-- --Rev. Russ in NY-- A posse ad esse
View hhhopks's profile
hhhopks
546 posts in 544 days
#8 posted 406 days ago
You got lot of suggestions here, so you definitely don’t need me (suggest or physical help).
Good Luck.
-- I'll be a woodworker when I grow up. HHHOPKS
View Woollymonster's profile
Woollymonster
23 posts in 407 days
#9 posted 398 days ago
Read this if you haven’t already. My Review. This thing comes fully assembled except for the fence and rails. The only method the manual gives is lifting via the strap and hoist method. It’s not going to be easy to disassemble but I’m sure it can be done.
Oh yeah…. Powermatic really does not exist anymore. The importer of that brand name is now Walter Meier. That is who you get when you call customer support.
86978 posts in 1743 days
#10 posted 398 days ago
pay some folks to move it in it will be far less than back surgery and a broken new saw :))
View Lee Barker's profile
Lee Barker
1884 posts in 1017 days
#11 posted 398 days ago
+1, Jim. Sub it out. Better in every way.
Kindly,
Jeff Stroomer
2 posts in 407 days
#12 posted 397 days ago
Thanks for all the good suggestions. I phoned Walter Meier today and asked them how to get the saw into my basement. Here are the details.
The tech support guy tried to be helpful, but it was clear that no one had ever asked him how to do this. The “free residential delivery” that Walter Meier offers gets the saw off the truck and onto my driveway, but that’s it. To get the saw from my driveway to the outside of my basement most likely requires a forklift. The saw is > 80” tall, and my doorway into the basement is 76” high, so I’ll have to get the saw horizontal on a dolly. If I remove the table and motor from the saw, the weight is reduced to about 600 lbs, so it’s still a beast.
He suggested calling some piano movers and hiring the job done. I don’t know what that’s going to cost, but it’ll be on top of the $4,700 they charge for the saw itself.
I was kind of surprised they hadn’t answered this question before. Do they not sell the saw to residential customers? Or maybe almost all residential customers have a shop in the garage?
-- Jeff Stroomer
View SnowyRiver's profile
SnowyRiver
45638 posts in 1647 days
#13 posted 397 days ago
That would be my suggestion too….call a piano mover. I had a piano moved once from the main floor of my house to the lower level. They took it outside and came in the walkout patio door. I dont know what the piano weighed, but I couldnt even lift an end of it, but it was amazing how they did that. Better them then to hurt yourself.
-- Wayne - Plymouth MN
View AHuxley's profile
AHuxley
208 posts in 1488 days
#14 posted 397 days ago
I think most hobby woodworkers either have a shop that is accessible with a pallet jack (most drivers are willing to wheel them in) or they know about their issues and make a plan.
I would hire it done, I have dealt with many bandsaws at or significantly above that weight and even on flat ground they can be a bear, the height and high center of gravity make them even more of a pain than most other machines, even if the weight is the same.
If you don’t hire it done, I would get the motor and table off and lay it down on a purpose built skid and winch it down assuming you have somewhere to anchor to. Be sure your stairs don’t need any extra support before you put that much weight on them, especially if you are going to have people on the stairs with it!
View remi1023's profile
remi1023
18 posts in 974 days
#15 posted 397 days ago
I have moved alot of heavy commercial kitchen equiptment…used a air sled…kinda like a huver craft for moving. Here in Cincinnati some of the larger tool rentals have them…good luck…
Mike
