"Skirting" the ROS
Forum topic by niki posted 2213 days ago 761 views 0 times favorited 6 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 2245 days
2213 days ago
Good day
As I promised yesterday, here is the “skirting” of the ROS.
I used two layers of “weather tape” (each 5/32” thick) to clear the orbit (you just peel the paper and glue it).
Over the weather tape, glue carpet tape.
The “iron on” tape is 1-9/16” wide (40 mm) but I think that you can use even cardboard.
The DC is superb – no dust at all.
I’m using it already 6 months and did not have to change the “skirt”.
Sometimes, I’m asking myself; “Why they (the manufacturers) don’t do it build in”....
Regards
niki
View gizmodyne's profile
gizmodyne
1762 posts in 2255 days
#1 posted 2213 days ago
Interesting. I might give this a go. I need to get a new connector for my sander first. Thanks for posting this.
View WayneC's profile
WayneC
9596 posts in 2263 days
#2 posted 2213 days ago
Cool. Thanks for sharing another great idea Niki.
View woodspar's profile
woodspar
710 posts in 2265 days
#3 posted 2212 days ago
Niki, you ought to publish a woodworking hints book.
-- John
Dick, & Barb Cain
8681 posts in 2465 days
#4 posted 2212 days ago
Great idea, but I have one suggestion that may improve the suction. Cut a few notches along the bottom of the plastic strip. Without a source for air the vacuum doesn’t work as good.
You’ll notice on vacuum attachments, always have notches for air flow. Did you ever notice when you put your hand over a hose end, the RPM goes up. That means the vacuum isn’t working. Actually there’s no load on it.
View niki's profile
niki
#5 posted 2212 days ago
Thank you for your replies
Woodspar
If I sit down to write a book, I’ll not have time to make jigs…that is greater pleasure…
Dick
You are correct about the notches but, (always there is this but….:-)
As you noticed, I glue the “skirt” without the sanding paper mounted to the sander so, the sanding paper provides small space that lets me to operate the shop vac at “minimum” power (and it’s also quiet).
I feel some “vacuuming” action (the sander sticks to the board) but the DC is very effective.
Of course if you are using one of the “big boys”, it’s better to make some notches as you suggested.
niki
34367 posts in 2566 days
#6 posted 2211 days ago
Another great modification Niki.
