4/4 cedar surface planed on 2 sides
Forum topic by jeffroL posted 412 days ago 881 views 0 times favorited 7 replies Add to Favorites Watch
View jeffroL's profile
jeffroL
10 posts in 473 days
412 days ago
Topic tags/keywords: cedar
Hi
I’m trying to reconcile some inconsistencies and was hoping to get some help. Some folks advertise that their 4/4 stock is 13/16” thick smooth 2 sides, whereas others have it as 1” thick S2S. Should it not be standard?
So when they advertise that the stock is 3/4” (smooth on 2 sides), is it truly 3/4”?
Thanks
Jeff
7 replies so far
jeffroL
#1 posted 412 days ago
BTW, I was also trying to find a place I can go to to get lumber in and around Chester Counter nearly Philly – with good broad selection and also good advice.
Thanks
Jeff
View cabmaker's profile
cabmaker
1029 posts in 979 days
#2 posted 412 days ago
Jeff, good luck on your reconciliations. No matter where you are 4/4 stock is one inch thick. One might make referance to it as 4/4 after surfacing but the fact remains if it is not one inch it is not 4/4. Most material handlers that do rough milling will provide a 13/16 as that is the most desired by the cabinetmaking industry. Cabinet shops ultimately end up with 3/4 nominal thickness after their own milling processes. If one is offering stock as s2s that simply means it has been planed on two sides without a straight edge. If it is offered as surface two sides with one edge straghtlined (most common) It will be referanced as SLR (straghtlined ripped or SLR 1E). There never used to be anything called s4s to my knowledge.I do understand what one is talking about when they use that term but the real world term would be S2S 2E.Dont assume your potential supplier understands it all, sometimes they need training. BTW I built ,delivered and installed a couple of tech labs in your town a few years ago. That was the only experiance I ever had there and I gotta tell you everyone I crossed paths with there were the nicest bunch of folks I ever delt with. Enjoy the journey,JB
View HerbC's profile
HerbC
778 posts in 1030 days
#3 posted 411 days ago
It’s my understanding that 4/4 hardwood lumber, when initially rough milled at the sawmill is 1 1/8” thick. It normally shrinks slightly during drying, and typically is 1” to 1 1/16” thick when dried. When milled (planed) for S2S it may be as thin as 13/16” thick.
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View BigMig's profile
BigMig
106 posts in 784 days
#4 posted 411 days ago
Delaware County Supply has very good lumber selection in the Phila surrounding area – just south of Phila on I95. Farther out – Hearne Hardwoods has excellent exotic selection and absolutely expert information about what they sell.
-- Mike from Lansdowne, PA
View WDHLT15's profile
WDHLT15
687 posts in 646 days
#5 posted 410 days ago
Herb, you are exactly. The Industry standard for rough sawn hardwood lumber is 1 1/8” thick. That is the thickness that I cut to on my mill for 4/4. It easily planes to 7/8 and most times to 15/16.
-- Wood-Mizer LT15
jeffroL
#6 posted 410 days ago
Thanks folks. I’m now looking at buying some lumber off eBay and the guy selling it has Spanish cedar for sale and has it advertised as 4/4 S2S. In his detailed description he indicated that the thickness is actually 1”. It just see,s like there ire no standards.
View doninvegas's profile
doninvegas
311 posts in 1078 days
#7 posted 410 days ago
I always thought that 4/4 S2S was 15/16” and 5/4 S2S was 1”. At least that is what I have gotten. I get my Cedar 5/4 rough which is 1 1/4”.
-- "Courage is being scared to death -- but saddling up anyway."
