curly cherry finishing
Forum topic by INDY22 posted 04-06-2012 09:23 PM 4439 views 0 times favorited 9 replies Add to Favorites Watch
View INDY22's profile
INDY22
3 posts in 2238 days
04-06-2012 09:23 PM
Hello all,
I am a not a new wood worker and came across some curly cherry. I would like to make a chest out of it, but need some help in finishing. I am not too much of a fan of shellac—mainly found it seals the wood too much for nice figure. Maybe I am doing something wrong, but have even cut it back to 1lb and still lose the figure. I know there are a lot of opinions out there, but I am looking for something simple to bring out the figure of cherry and need to add a little color. I know, some say it is just plain wrong to color chery, but want it to darken a little early on. Any help would be greatly appreciated.
9 replies so far
View BTimmons's profile
BTimmons
2303 posts in 2482 days
#1 posted 04-06-2012 09:31 PM
A day of being in full sunlight will darken cherry a little bit. As far as extremely simple finishes go, you might go with a few coats of boiled linseed oil. It penetrates deep without building a film, it really brings out figure, and will darken anything slightly with a yellow tint. Once it cures you can always put on a clear top coat if you’re concerned about protection.
-- Brian Timmons - http://www.BigTWoodworks.com
View jdmaher's profile
jdmaher
427 posts in 2576 days
#2 posted 04-06-2012 09:40 PM
Tung oil. 1/2lb cut of garnet shellac – padded on. Top coat as you please.
-- Jim Maher, Illinois
View killerb's profile
killerb
150 posts in 2395 days
#3 posted 04-06-2012 10:40 PM
This was done with lockwood dyes. Antique cherry. I sand to 150, I raise the grain first with water. Let it dry and sand again at 150. Add the dye. I mix it at 1 ounce to a quart of hot water. Let it dry and then put a coat of general finishes clear seal a cell. Let that dry and top coat with lacquer or other top coats.
-- Bob www.bobkloes.com
INDY22
#4 posted 04-06-2012 11:31 PM
Bob,
Thanks—exactly what I am looking for. As far as Lockwood dyes—is that #911 Antique Natural Cherry? That is the only antique cherry that I can find. What is on your chest is beautiful and tooks a little more red than the natural cherry that I found. Thanks again!
Carl
View Clint Searl's profile
Clint Searl
1533 posts in 2358 days
#5 posted 04-06-2012 11:41 PM
Solvent NC lacquer; no more, no less.
killerb
#6 posted 04-07-2012 12:51 PM
Yes that is the one. The early american cherry is also very nice. A little darker. The cherry tone amber is nice if you want it a little lighter. Good luck and glad to help. bob
INDY22
#7 posted 04-12-2012 10:10 PM
Bob,
Did you use any wood conditioners before you started staining? Thanks!
Carl
killerb
#8 posted 04-12-2012 10:28 PM
No, not for figured woods. You want the blotch. That is what goes into the figure. I use an ebony dye first to raise the grain. I dilute it alot. About 1/8 oz or less to a quart of hot water. This gets into the curl and gives it a little color. It works best on flame birch and tiger maple. Hope this helps. bob
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2847 days
#9 posted 04-13-2012 12:12 AM
I just finished an almost quilted cherry bed and headboard. I darkened it with Potassium Dichromate and applied five coats of Liberon Finishing Oil. The photo doesn’t give justice to the figure, but The Liberon really made it pop, but I think you can see the finish especially the one of the leg . I’ve used this combo on several pieces and love it.
-- Ken
