| Forum topic by Brandon | posted 409 days ago | 675 views | 0 times favorited | 10 replies | ![]() |
409 days ago |
Topic tags/keywords: cyrpess screen door finish I generally don’t make things that are going to be subject to the elements, except when I’m using pressure treated wood. But now I’m making a screen door out of cypress (that depraved wood) and want to give it the best protection as possible against the elements. Any suggestions? -- "hold fast to that which is good" |
10 replies so far
#1 posted 409 days ago |
Do you want to keep the color natural or darken it up? Im going to guess that a spar / marine varnish would be the way to go but cypress is naturally rot resistent (to a point). Ive used general finishes dye stain on it with good results. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#2 posted 409 days ago |
Thanks Chris. We chose Cypress because it is rot resistant—but still want to give it the most longevity possible. -- "hold fast to that which is good" |
#3 posted 409 days ago |
I’ve always had good luck with spar varnish. I had some pine Adirondack chairs that lasted over 20 years sitting outside using it. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#4 posted 409 days ago |
I have had good luck with polyurethane. Three coats otta do. The only pain about poly is you can’t spray it. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#5 posted 409 days ago |
PENOFIN … I used it on a pair of Cypress doors I made about 5-6 years ago … looks great. -- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ... |
#6 posted 408 days ago |
Pintodeluxe, I spray a lot of Spar Urethane using a cheapo Home Depot gun. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#7 posted 408 days ago |
Our home is built out of Cypress, studs, beams, floor joist, tongue and v groove vaulted ceilings, outside walls and decks, outside doors and window frames, Never had anything put on it and was built in 1974. No rot, no bugs, no mouses. Never had an exterminator in it. About every four or five years I pressure wash the outside and it looks almost like new Cypress all over again. -- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com |
#8 posted 405 days ago |
Wipe it down with Mineral spirits before, if you put a finish on it. Cypress is rot and bug resistant and will color naturally I tried to use a finish on it and it will not look so good in a year or two. In fact 6 months it may yellow or you may see ALLIGATORING using the wrong finish. Are you using sinker cypress? |
#9 posted 405 days ago |
I’m not sure what sinker cypress is. I didn’t purchase the wood, but my father-in-law (for whom I’m building the door) purchased it. Also, what on earth is alligatoring? EDIT, just did a google image search for alligatoring wood. Ugly stuff. :-) -- "hold fast to that which is good" |
#10 posted 376 days ago |
I have wooden screen doors on all my exterior doors, and on some interior ones as well. They work great and will last many years if they are properly primed and painted. Poplar is very easy to paint but one of the least resistant woods in the hardwood family. Yellow pine is ok, but white pine is poor.. Cypress, cedar, fir works really pretty well. |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1525 |
3542 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6150 |
