What to steam wood with?
Forum topic by CartersWhittling posted 04-04-2012 03:09 PM 4732 views 2 times favorited 19 replies Add to Favorites Watch
View CartersWhittling's profile
CartersWhittling
453 posts in 2673 days
04-04-2012 03:09 PM
Topic tags/keywords: question wood steamer steam bending
Hello.
I am trying to find a way to produce the steam for wood bending. Could you guys help me out and let me know the different ways you can produce the steam for a steam box? I am wanting something that doesn’t take up loads of space and doesn’t cost a lot of money either.
-- And whatsoever ye do, do it heartily, as to the Lord... Colossians 3:23
19 replies so far
View waho6o9's profile
waho6o9
8191 posts in 2576 days
#1 posted 04-04-2012 03:29 PM
http://www.rockler.com/product.cfm?page=30714&site=ROCKLER&filter=steam%20bending%20kit
This may give you some ideas and good luck on your project.
Your hand made plans are awesome, keep doing the good work!
View Scot's profile
Scot
344 posts in 3395 days
#2 posted 04-04-2012 03:34 PM
Used professional wallpaper steamers work fantastic and are safe. I got mine on ebay for $175 (almost new). They usually run $200-300. I got lucky on mine and caught a better than usual deal.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View Dallas's profile
Dallas
3599 posts in 2486 days
#3 posted 04-04-2012 03:37 PM
I use a hot plate, some PVC pipe and an old stove top coffee pot. Total cost about $10 at yard sales.
View luv2learn's profile
luv2learn
2763 posts in 2302 days
#4 posted 04-04-2012 04:27 PM
I like this method DIY Steam Box
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
View Richard's profile
Richard
1916 posts in 2689 days
#5 posted 04-04-2012 04:55 PM
Norm abrams has good example on an episode that he made a bentwood hat rack. Not sure of the episode name or number but I will try look it up when I get home.
It used a brand new gas can on top of a burner and some radiator hose and a large PVC tube with a cap on it.
View poopiekat's profile
poopiekat
4355 posts in 3733 days
#6 posted 04-04-2012 05:30 PM
I’ve got my eye on the side burner of my gas grille. The one for cooking a pot of corn on the cob, or lobstah. Plus it’s already outdoors. Should be more than enough heat for a pot of water and some stovepipe flue.
117091 posts in 3576 days
#7 posted 04-04-2012 06:04 PM
I use an electric tea kettle type steamer and a hose into a DIY steam box. Many times you can soak wood in hot water
and bend it if it’s thin enough or just use thin strips just glued together into a lamination with out heat at all.
http://books.google.com/books?id=s_YDAAAAMBAJ&pg=PA68&lpg=PA68&dq=mike+dunbar+steam+box&source=bl&ots=B2v9jCo9PZ&sig=vH_txjVHAZxlZ1WxM4LozKBPlNM&hl=en&sa=X&ei=BIt8T5mMJsmPiAKOh4H1DQ&sqi=2&ved=0CDcQ6AEwAw#v=onepage&q=mike%20dunbar%20steam%20box&f=false
View YorkshireStewart's profile
YorkshireStewart
1130 posts in 3900 days
#8 posted 04-04-2012 06:09 PM
For my yew Windsor chair, I used a domestic wallpaper stripper connected to a length of rainwater pipe. The plastic pipe did go a bit limp! However, supported on a length of timber, all was well.
Click for details
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
View DrDirt's profile
DrDirt
4424 posts in 3741 days
#9 posted 04-04-2012 06:21 PM
I’m with A1Jim – - -though it is hard to find a METAL electric kettle anymore.
Most are plastic with a thermal cutout, that shuts off at the most inopportune times…..
Check out the salvation army/DAV thrift stores see if you can find one of the old 1950-1970 era ones
View Jeff's profile
Jeff
433 posts in 3193 days
#10 posted 04-04-2012 06:32 PM
I echo Scot’s wallpaper steamer idea. Although I use a Wagner steamer from Lowes. It’s cheaper. It depends on the volume and duration of steam you need. I have a 6” ABS tube, 4 ft long I use for relatively small pieces. The steamer lasts for about 45 minutes if started full.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3114 days
#11 posted 04-04-2012 06:55 PM
basicly you collect some water before you boil the water and use the steam from it …. LOL
okay joke aside :-)
the cheapest is to steal ….eeergh borrow moms stealkettle and leed the steam into
a steam bed made of wood and 1-1½ meter of cobbertube with holes and an endcap
there is several on L J that has made one and posted them as projects
you can use one of the modern kettles if you shortcut the thermo cuout
but then you have to be very carefull not to let it boiling dry….. you don´t want a fire
now your water is steam … lol
good luck with your steam project
Dennis
View shipwright's profile
shipwright
7980 posts in 2797 days
#12 posted 04-04-2012 07:06 PM
I used to use an oil fired pressure washer modified to dramatically reduce the water going through but I was steaming much larger things than I suspect you are.
One thing to think about if you are steaming many or thick pieces, is that hotter steam created under pressure will get the job done more quickly. I’m not sure exactly what the temperatures were that we used to run but 225 to 230 degrees sounds about right. We went by the appearance of the steam more than the temperature. You want it about ten degrees lower than the point where it becomes clear. That is if it’s nice and white, it’s not too hot.
Inch and a half Oak will be bendable in about half the time it would take at non-pressure temps.
CartersWhittling
#13 posted 04-04-2012 10:00 PM
Thanks for all the help guys, it is much appreciated.
View Howie's profile
Howie
2656 posts in 2922 days
#14 posted 04-04-2012 10:07 PM
I bought a wallpaper steamer at Goodwill for 10 bucks. Works good for thin strips(up to 1/4”)
-- Life is good.
View BobM001's profile
BobM001
388 posts in 2329 days
#15 posted 04-05-2012 01:06 AM
I recall seeing a “rig” that used a large pot that the branch of a 12” 24 gauge tee was inserted into the pot. Then equal lengths of the same sized pipe wher inserted into the “run” sides of the tee. These pieces were long enough so that there was about 6” of void on each end based on the length of the pieces to be steamed. They were doing bent wood rockers as I recall. A short piece of “riser” into the tee branch would keep any liquid from contacting the wood if a hard boil was in process. The steam poured out of the ends of the pipes. Perhaps a turkey fryer burner/pot would make a good source for doing larger pieces. Find a reducer that would fit the top of the pot and build from there.
-- OK, who's the wise guy that shrunk the plywood?
