Bleeding Bloodwood?
Forum topic by Wingstress posted 411 days ago 616 views 0 times favorited 4 replies Add to Favorites Watch
View Wingstress's profile
Wingstress
321 posts in 1682 days
411 days ago
I know this question has been asked before, but I can’t seem to get a good answer. I just did a marquetry inlay with bloodwood and Satin wood (yellow heart). I intend to scrape, not sand, and then use compressed air to blow away the red dust. However, I know from experience as soon as I touch that stuff with poly or shellac or what ever, its gonna bleed. So I was wondering if there was a sealer or anything I can put on it that doesn’t bleed? Can I use some tung oil followed by some shellac or top coat poly or something? Thanks!
-- Tom, Simsbury, CT
View Doss's profile
Doss
777 posts in 431 days
#1 posted 411 days ago
I’ll go into this with the disclaimer that I am not an expert on finishes, but here’s some ideas:
Try a spray on finish
Try an oil finish
Try sanding sealer
I don’t know much else to tell you, but from what I’ve read, bloodwood likes to bleed into lighter woods.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View majeagle1's profile
majeagle1
1382 posts in 1663 days
#2 posted 411 days ago
This is what I have done and it seems to work well for me:
Either complete your sanding / scraping, then blow all the red dust away as you plan….. then:
I wipe the surface with Mineral Spirits and that seems to get rid of 99% of the slight pinkish tone that was left.
Then go ahead with your finish…..
It has worked for me using bloodwood and Curly Maple…...
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
View Sirgreggins's profile
Sirgreggins
206 posts in 402 days
#3 posted 402 days ago
i would just put some painters tape down over the other woods you dont want it to bleed on and do the shellac. If thats not viable because you have a lot of small pieces i agree with Doss, try a spray finish
Wingstress
#4 posted 328 days ago
Hey thanks everyone, this is what I ended up doing. It worked great!
scrape (no sand)
wipe with mineral spirits
spray shellac
finish with poly
Here is the project post and video
http://lumberjocks.com/projects/67783#comment-1292356
http://www.youtube.com/watch?v=r8rOdPwPsqc
