Plan for crab?
Forum topic by Toninho posted 04-03-2012 08:40 PM 1546 views 1 time favorited 13 replies Add to Favorites Watch
View Toninho's profile
190 posts in 2761 days
04-03-2012 08:40 PM
Topic tags/keywords: question
Good evening friends! A few days ago a friend of mine found this shoe and asked me to make one! Does anyone have a plan to help!? Thank you!
-- António Guerreiro
13 replies so far
View MrsN's profile
984 posts in 3459 days
#1 posted 04-03-2012 09:06 PM
I don’t have any plans, but I totally want one, or two, of these!
#2 posted 04-03-2012 09:25 PM
I also want to go for me one or two MrsN!!
View DocSavage45's profile
8476 posts in 2776 days
#3 posted 04-03-2012 09:30 PM
Looks like a number of equally divided segments in a 360 degree circle. you can lay out a pattern and repeat it by one half the segment? pre drill and use a right angle drill to set the difficult ones. of course glue and screww make a pretty tight joint. either buy the plugs or purchase a plug cutter.
Good hunting1
-- Cau Haus Designs, Thomas J. Tieffenbacher
View bullhead1's profile
228 posts in 2182 days
#4 posted 04-03-2012 09:30 PM
Looks like it was made with a lazy susan spindle.
View Scot's profile
344 posts in 3329 days
#5 posted 04-04-2012 12:36 PM
I made one of these years ago. Simple build and you can make it as tall as you want.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View helluvawreck's profile
30512 posts in 2800 days
#6 posted 04-04-2012 12:44 PM
My wife could use one of these but we don’t have room. I don’t understand why women have so many shoes but they do. She has a pocket rack that is on the inside of the door that goes from top to bottom. Every night I expect to be awakened by a loud noise as the door falls off but so far it hasn’t happened. Your unit is much safer. Nice work.
-- helluvawreck aka Charles,
View poopiekat's profile
4335 posts in 3668 days
#7 posted 04-04-2012 01:16 PM
Hmmm, I’m thinking….who’s to say you couldn’t make one of these for storing your handplanes? Yee-haw!
View dannelson's profile
191 posts in 2304 days
#8 posted 04-04-2012 01:17 PM
I have one . I dont know how you would cut it though. I cut mine on the cnc however if you email me I could cut you a pattern so you could use a flush bit in a router . or I could cut the pieces and ship or I can try to chuck up a sharpie marker in the spindle and trace it let me know I cant post an image I only have a bitmap file I could send you directly. any size diameter and number of dividers you want with the click of a mouse. Dan Nelson
-- nelson woodcrafters
View ksSlim's profile
1272 posts in 2823 days
#9 posted 04-04-2012 01:30 PM
free standing turn table is stable so long as the height is less than twice the diameter, unbalanced load acts as a slingshot.
-- Sawdust and shavings are therapeutic
View HalDougherty's profile
1820 posts in 3170 days
#10 posted 04-04-2012 01:32 PM
Looks very simple. Lay out 8 pairs of shoes, draw a circle around them, make a circle in the center to leave enough room for the circle to spin on a black pipe, Cut out a stack of plywood circles, decide how much space to leave between levels, and cut the dividers to fit. Then I’d screw and glue em to the bottom circle and work my way up the stack. It would make a nice addition to a walk in closet. The bottom circle can be supported on a few roller bearings. Like this one from Harbor Freight.
Then build a cabinet around your shoe holder. The space you have to use and the shoes will determine the dimensions of your lazy shoe rack.
-- Hal, Tennessee
View crashn's profile
528 posts in 2399 days
#11 posted 04-04-2012 03:17 PM
I thought this one was about crab?
-- Crashn - the only thing I make more of than sawdust is mistakes
View fredf's profile
495 posts in 3643 days
#12 posted 04-04-2012 11:23 PM
I think you might need a circular wall in the back so the shoes down work there way out to jam or fall in the corners
-- Fred, Springfield, Ma
#13 posted 04-06-2012 09:37 PM
Hello friends! Thanks for your opinions, helped me a lot and dicidir how to build this mobile for my shoes messy!
Good Easter!
