Cracked Stone
Forum topic by KPW posted 04-03-2012 08:00 PM 1929 views 0 times favorited 14 replies Add to Favorites Watch
View KPW's profile
KPW
226 posts in 2602 days
04-03-2012 08:00 PM
Topic tags/keywords: question
Hey girls and boys, I need some advice on a cracked sharpening wheel on my Delta wet/dry model 23-700. It seems the 2”x10” dia. aluminum oxide stone has developed a radial crack all the way to the center. I’m not sure how or why it happened. This stone is the slow moving wet stone. Now when I go to put an edge on anything it’s like jumping the creek on every revolution. Could this be repaired, or is it a big round bench stone now? And if it can, how would I go about doing it? Thanks in advance for any and all advice.
-- Ken --------- never try and put 5 lbs. of tenon in a 3 lb. mortise.
14 replies so far
View lieutenantdan's profile
lieutenantdan
176 posts in 2539 days
#1 posted 04-03-2012 09:52 PM
It is probably a goner.
-- "Of all the things I have lost in life, I miss my mind the most."
117416 posts in 3810 days
#2 posted 04-03-2012 10:00 PM
I never use anything that spins that’s broken or cracked . It may have been defective from day one hard to tell.
View Bagtown's profile
Bagtown
1739 posts in 3964 days
#3 posted 04-03-2012 10:06 PM
Throw it away.
Extremely dangerous to use.
-- Mike - In Fort McMurray Alberta
View pvwoodcrafts's profile
pvwoodcrafts
244 posts in 4155 days
#4 posted 04-03-2012 10:12 PM
Having worked in a grinding shop for 15 years I can tell you you need to get it off your machine. Its a disaster waiting to happen.
-- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net
View SnowyRiver's profile
SnowyRiver
51457 posts in 3714 days
#5 posted 04-03-2012 10:16 PM
I agree…dont take a chance with something that spins. Install a new one.
-- Wayne - Plymouth MN
View jackass's profile
jackass
350 posts in 3946 days
#6 posted 04-03-2012 10:20 PM
Bagtown said it right, throw it away. I know of an incident in a car dealership where a cracked stone embedded itself in a ceiling. Had it broken at the right nano second, it likely would have killed the operator. Everyone above is correct.
Jack
-- Jack Keefe Shediac NB Canada
View KPW's profile
KPW
#7 posted 04-04-2012 05:59 PM
Thanks guys, I just thought since it runs at such a slow speed that maybe it could be saved but it doesn’t sharpen right anyway. Do I have to go to Delta for a new one? Or does anyone know of an after market link?
View KPW's profile
KPW
#8 posted 04-04-2012 09:36 PM
So come to find out the 10”x2” al.ox wet wheel on my Delta 23-700 grinder is obsolete at Delta. Need help finding a replacement or it’s on to buying a new sharpening system. Ouch!!!!!!
jackass
#9 posted 04-10-2012 12:38 AM
Have a look on E-Bay you just might get lucky.
Jack
View geoscann's profile
geoscann
258 posts in 2513 days
#10 posted 04-10-2012 12:42 AM
If your shop aint heated and it got below freezing it could have cracked it.
-- BIG geo ---Occam,s razor The simplist answer is often correct
View sandhill's profile
sandhill
2128 posts in 4157 days
#11 posted 04-10-2012 12:55 AM
Every answer here is the right one but I would keep it and use it laying on its side to do hand sharpening. Call me cheep! Don’t even chance it one time.
All you should need is the arbor size to get another wheel.
geoscann
#12 posted 04-10-2012 01:03 AM
The wheel for the grizzly slow speed ten inch wheel should fit it.
View Tom148's profile
Tom148
39 posts in 2498 days
#13 posted 04-10-2012 01:06 AM
Might want to take a look at the Norton line of abrasive stones. They should have a current replacement
-- Tom
View KPW's profile
KPW
#14 posted 04-10-2012 08:11 PM
Thanks guys, I actually found a Delta replace on ebay.
