bowl turners, please advise...
Forum topic by gridlockd posted 04-03-2012 12:05 AM 1045 views 0 times favorited 3 replies Add to Favorites Watch
View gridlockd's profile
gridlockd
141 posts in 2413 days
04-03-2012 12:05 AM
ok, I have seen several vids on u tube where this guy or that guy is turning a bowl. it comes to the finishing and I see them grab an air powered sander with what looks like about a 3” sanding disc on a conical foam backer pad. I go “ooohhh, i want one of those!” I checked the big box stores hoping to pick one up…no luck, all they have are the 6” jobs and that is too big for what i want. so where do you guys get these sanders/discs/backer pads, etc? and could i use a die grinder instead? or would that be too unwieldy?
Thanks in advance to all responses!
-- Gridlockd
3 replies so far
View darryl's profile
darryl
1795 posts in 4355 days
#1 posted 04-03-2012 12:12 AM
View hairy's profile
hairy
2721 posts in 3561 days
#2 posted 04-03-2012 12:13 AM
http://vinceswoodnwonders.com/back-up-pads/
-- My reality check bounced...
View JamesVavra's profile
JamesVavra
304 posts in 3345 days
#3 posted 04-03-2012 06:25 PM
I use an electric, right-angle drill from harbor freight
I use the “2 blue discs and these sanding pad/holders
Air-powered sanders will last longer; I just replace my HF sander every 2 years (the bearings wear out after a while).
