Refinishing trim
Forum topic by bozekk posted 04-02-2012 11:21 PM 836 views 0 times favorited 3 replies Add to Favorites Watch
View bozekk's profile
bozekk
6 posts in 2577 days
04-02-2012 11:21 PM
I finally got all of my new treads in. I ended up needing to remove some trim in order to get the stairs installed. The builder fired a boatload of nails in the trim so I some of trim was removed and it is too damaged to replace.
So, at the bottom of my steps, I have one side that will have to be refinished from bare wood. The other side is simply red oak with a poly finish.
My thoughts are to sand down the poly on the pre-finished side and then stain and re-poly. It’s not a lot of trim but I do have to sand the newel post and trim.
I don’t want to use a chemical to remove. I am thinking if steel wool – is that practical?
Thanks to all!
Plan to publish the project. It’s my first real woodworking adventure that really meant something.
Keith
3 replies so far
View Gabe C.'s profile
Gabe C.
288 posts in 2462 days
#1 posted 04-05-2012 03:23 AM
Man, I really don’t know. How abrasive IS steel wool? Would sandpaper of a decent grit do a faster job? Information that I need to look up one of these days. Good luck!
-- If I could just get this whole "Time/Money" problem figured out...
bozekk
#2 posted 04-05-2012 04:15 AM
I have pieces of the scraps that I pulled. I am going to try 150 and 180 grits first and then go lower. I want to do by hand so I don’t have to set up a surround around stairs if I were to use power sanding. I’ll post here what I find out.
Thanks!
Keith
View Drew Nyman's profile
Drew Nyman
19 posts in 2389 days
#3 posted 04-05-2012 04:37 AM
You might try a scraper instead of sand paper
-- Don't be in such a hurry, do it right the first time.
