glue plastic lumber?
Forum topic by Danpaddles posted 04-02-2012 09:56 PM 3167 views 0 times favorited 8 replies Add to Favorites Watch
View Danpaddles's profile
Danpaddles
573 posts in 2275 days
04-02-2012 09:56 PM
I am thinking to repurpose some salvaged deck boards, the kind they make from milk jugs. I did some looking on suppliers web pages, but most references to gluing are a little vague, if not downright dismal.
I am thinking to run a dado lengthwise on the underside of slats, to use on a garden bench. Then, a narrow strip will be glued and screwed into the dado. I am trying to take out some of the flex of those plastic boards. So the glue will be pretty well protected from weather/ UV rays.
Anyone ever tried gorilla glue with those boards? One manuf. recommended Lexcel, but I can not find out anything about it, not even who makes it. I have a feeling it may be a polyurethane though. West Systems Epoxy talks about it a little, they recommend providing a means for a physical …. grip, or a surface preparation, to let their epoxy grab.
Using PolyU (Gorilla) is more appealing to me then using West systems, partly because I am a cheap SOB, I have almost no West Systems left in the can. And that stuff is not cheap.
Alternatively, I could just make a little bench, maybe only 2 and a half feet wide, then the flex would not be a problem.
Ideas? Thoughts?
thanks guys-
-- Dan V. in Indy
8 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2324 days
#1 posted 04-02-2012 11:14 PM
PL Polyurethane construction adhesive.
View Jeff's profile
Jeff
428 posts in 3157 days
#2 posted 04-02-2012 11:21 PM
From what I looked up many people suggest Gorilla glue but with some extra support such as you’re going to provide with the screws. Even a Trex rep suggested Gorilla. Let us know how it turns out.
View oluf's profile
oluf
260 posts in 3002 days
#3 posted 04-03-2012 01:56 AM
If you have enough material I would reccomend making the seat double thickness. Space your joints as far apart as possable. Glue the two boards together with construction adheasive and fasten with lots of screws up from the bottem. Got enough boards? make them three thick.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
Danpaddles
#4 posted 04-03-2012 03:31 AM
Well, Oluf, the curve of the bench would make it tough to just add thickness. I am actually using a 5/4 board, right now the bench has 3/4 wood on it. So I will be increasing the thickness some. But we have set the 5/4 boards on sawhorses, they are just not real strong.
Clint, I’m gonna look real close at the label on that PL Polyurethane construction adhesive. Might be just what I want. Otherwise, I have a bottle of Gorilla glue out there now.
This is a Spring Break project (my 16 y.o. needs to work off some bad karma) so I will know by the end of the week.
thanks a bunch for taking the time to post, this was just the help I was looking for!
-- Dan V. in Indy
View crank49's profile
crank49
4030 posts in 2934 days
#5 posted 04-03-2012 04:02 AM
If those boards are made from milk bottles, that is polyethelene plastic and there is no glue that will bond to that.
But, the construction adhesives, like PL, will stick to it pretty good, just not a solid bond like PVA on wood.
What kind of strip are you putting in the dado? Can it be proud of the bottom surface?
You are correct that plastic composite deck boards are flexible. They barely function as a walking surface and feel springy even with joists on 12” centers. Best thing I have come up with for repurposing this material is sill material under walls installed in a basement.
Danpaddles
#6 posted 04-04-2012 12:52 AM
Michael, I am looking to just add a strip of the same material- sticking proud by an inch or so, to keep it from bending so much. I will be able to pepper it with screws, anyway. Sticky may be good enough. And if the whole thing craps out next year, well, we will have had one year from the bench. We are not talking fancy stuff here, the original came from HP. But the cast iron is still in good shape.
I gotta have SOMETHING to keep this dang teenager busy. He thought he would be sleeping for the whole Spring break.
-- Dan V. in Indy
Danpaddles
#7 posted 04-07-2012 07:53 PM
We ended up using PL construction adhesive. With lots of screws, it is good. The whole project turned out great! He worked at it, painted some, cut the boards, drove some screws, and did the final assembly.
thanks!
-- Dan V. in Indy
Danpaddles
#8 posted 04-16-2012 03:15 AM
P.S.- there was some PL adhesive drippings on some his scraps. I was picking up today, noticed the drips, gave them a test. They have almost no grab on the poly wood, I could lift the globs off cleanly with my fingers.
Oh well.
hindsight is 20-20- but maybe I should have tried a hot melt glue gun. Some poly is weldable.
-- Dan V. in Indy
