How do you hand rub?
Forum topic by zindel posted 442 days ago 506 views 1 time favorited 4 replies Add to Favorites Watch
View zindel's profile
zindel
229 posts in 846 days
442 days ago
Okay so what is everyone’s steps to getting that great slick finish on their projects? As a background of what i am planning, i want to make a chess board out of walnut and maple….IDK what i will do for the chess pieces but thats another issue. Anyways i want to have a great mirror finish and i was thinking of using clear lacquer and hand rub. Anyone have better luck with varnish or lacquer when hand rubbing? should i put something else on there before i add the lacquer/varnish?
-- If you can't fix it with a hammer, You've got an electrical problem.
View AlaskaGuy's profile
AlaskaGuy
271 posts in 505 days
#1 posted 442 days ago
Maybe in here somewhere.
http://www.google.com/search?sourceid=chrome&ie=UTF-8&q=what+is+a+hand+rubbed+finish
89011 posts in 1773 days
#2 posted 442 days ago
Zindel
The staring point to a rubbed out finish is to make sure you have plenty of material to rub out. With lacquer I would spray (rattle cans are fine) 2-3 thin coats let dry then very lightly sand with 350grit add 2-3 more coats lightly sand with 600grit hundred repeat and sand with 1000grit then I would use some super fine rubbing compound with a buffer(if you don’t have a buffer you can use a ROS with a soft cloth like a diaper,after that hand rub some good furniture wax and buff by hand. At this point you should have a very glossy mirror like finish. I would suggest you try it out on a sample board first.
View DKV's profile
DKV
2040 posts in 700 days
#3 posted 441 days ago
Here is a great video of what you are looking for.
https://www.youtube.com/watch?v=P6Ny-s7vSzE&feature=youtube_gdata_player
-- I would drink a river of the kool aid before I took the smallest sip of the tea...
14932 posts in 2415 days
#4 posted 441 days ago
Like Jim said, the main thing is to have enough of a buildup. I used wipe-on poly for my walnut and maple chess table, but it involved many, many coats, and multiple sandings to level everything out. Keep in mind that walnut is an open-grained wood, so it will take a lot of finish (or a grain filler, like Crystalac) to get a glassy-smooth finish.
