CHEAP CRAFTSMAN/RYOBI T.S. INSERT IS NOT.....
Forum topic by Metrotek posted 444 days ago 547 views 0 times favorited 5 replies Add to Favorites Watch
View Metrotek's profile
Metrotek
134 posts in 881 days
444 days ago
The insert on my new Craftsman [which is obviously the same as my broken Ryobi] table saw sits below the surface of the stamped steel table; does anyone know how to correct this? The insert is a piece of #12 [?] gauge steel itself. It’s dangerous because as I come across the saw it bumps on the difference in height between the insert and the table climbing out, let alone detracting from what little accuracy can be obtained with this cheap piece of equipment generally. There are no adjustment screws; it’s too thin.
Help please….
-- “Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.” — Mitch Ratcliffe
5 replies so far
View bent's profile
bent
310 posts in 1866 days
#1 posted 444 days ago
how far is it off? can you put some tape on the bottom of the insert to shim it up?
View MT_Stringer's profile
MT_Stringer
789 posts in 1428 days
#2 posted 444 days ago
I discovered a whole box of shims in the drawer of my work bench. They are tin caps used in roofing!
Metrotek
#3 posted 444 days ago
The flanged area is barely 3/16” in width and it is off right at 1/16” in height to produce quite a bump. I even looked under the table to see if I might be able to rig something with adjustable Allen’s or similar. I rarely tilt my saw so it wouldn’t be a problem in this regard. Perhaps I should add a self-adhesive layer of some thin polymer to the top of the insert?
View Martyroc's profile
Martyroc
2708 posts in 503 days
#4 posted 444 days ago
How thin is it? You could always make a new insert out of some hardwood. I have a craftsman as well it uses small tabs on the insert that you can bend down to adjust the height.
-- Martin ....always count the number of fingers you have before, and after using the saw.
View gfadvm's profile
gfadvm
6907 posts in 887 days
#5 posted 444 days ago
I used the tape shim idea on my old Ryobi and it worked fine or make a new insert. Search “table saw inserts as there have been a lot of posts here.
