Removing a black moisture spot on Red oak
Forum topic by woodman88 posted 03-31-2012 01:19 PM 1029 views 0 times favorited 4 replies Add to Favorites Watch
View woodman88's profile
woodman88
144 posts in 2613 days
03-31-2012 01:19 PM
I know I have seen it on here but cannot seem to find in the forums.I have a Red oak ledge below a window behind the kitchen sink for plants.The GF thought would be nice for plants.Anyways it has gotten a large black spot from water being spilled on it.I know I have seen on here a chemical to use on it.Thanks
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2656 days
#1 posted 03-31-2012 10:41 PM
Oxalic acid. Done as part of a strip and refinish. Be sure to rinse off the crystals after it dries and before you sand as the airborne version can be irritating.
117062 posts in 3542 days
#2 posted 03-31-2012 11:02 PM
I agree with the use of oxclic acid, it is best to neutralize the surface before finishing with a table spoon on baking soda in a cup of water ,wiping down the whole are that has been treated with oxcilic acid, and then using clear water to rinse that.
woodman88
#3 posted 04-01-2012 12:46 AM
Thank you both so much I knew as soon as I seen oxclic acid that was it just couldn’t remember. Do you know if I can buy it at one of the big box stores? Thanks again
#4 posted 04-01-2012 01:15 AM
I’m not sure if they sell it at box stores if not check drug stores.
