HELP! IS THIS THE SAME AS THIS
Forum topic by Metrotek posted 03-30-2012 05:50 PM 1946 views 0 times favorited 6 replies Add to Favorites Watch
View Metrotek's profile
Metrotek
132 posts in 2830 days
03-30-2012 05:50 PM
Topic tags/keywords: jig tip question tablesaw jointer milling machinery industrial homemade diy miters cutting angles sled
In terms of functionality and/or results, is the last jig the same as the first two? I like the last one and I see no way that it can’t be made to give the same results as the first two. When you see these from Woodpecker [Incra jig] or Rockler, aren’t they just a different style of angle cutting device? The last one seems to be more versatile and more fun for me to build. Obviously, it isn’t as convenient as haveing scribed off divisions of angles but it certainly appears to me that it can achieve any angle and be made to accept any number of accessories.
I was going to make it an attachment for my sled but if I ever get this router as a jointer business down to more practically mill runners, I’ll just make it another sled; a sled board.
Please give your insight into this before I start going to town.
Thank you for your assistance and help
-- “Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.” — Mitch Ratcliffe
View jusfine's profile
jusfine
2422 posts in 3072 days
#1 posted 03-30-2012 05:55 PM
You may have a greater range with the arc on the first one, but do you need it?
I would go to town if I were you!
All the Best!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View waho6o9's profile
waho6o9
8424 posts in 2723 days
#2 posted 03-30-2012 06:29 PM
I would incorporate some sort of hold downs to keep your stock from moving when it’s being cut.
Other than that, have at it.
View nikko18's profile
nikko18
15 posts in 2838 days
#3 posted 03-30-2012 06:49 PM
I would think the third would be harder to set to square. The first two you have only 1 degree of freedom, so just a stop will set it.
-- Time flys like an arrow, fruit flies like a bannana
Metrotek
#4 posted 03-30-2012 07:28 PM
I can scribe lines of different angles on it for rapidly setting it correct.
You are definitely right about the hold downs because even with a fixed fixture the saw attempts to draw the material into itself. I was thinking about the style of clamps with some modification, in the photos included herein.
View blackcherry's profile
blackcherry
3338 posts in 3969 days
#5 posted 03-30-2012 07:28 PM
Technical the same, but as far as repeatability goes the first two will smoke you every time as well as changing angles back and forth. But hay you save yourself some coin in exchange for time spent working.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3433 days
#6 posted 04-02-2012 09:26 PM
Without a doubt I would go with the second sled—-oh wait, I did!
They basically all do the same thing. It depends on how far you want to go with the build. I use the angled fence only for odd stuff. I use this sled more for larger pieces at 90 degress. When I am doing 45’s, I have 2 other sleds, depending on what I am doing.
-- http://shepherdtoolandsupply.com/
