splitting logs
Forum topic by Betsy posted 116 days ago 195 views 0 times favorited 9 replies Add to Favorites
View Betsy's profile
Betsy
1777 posts in 377 days
116 days ago
I have been wanting to ask this for a while – but keep forgetting until I go in my backyard and see the pile of logs behind the shed. When I moved into my house I had several trees that were hanging over the house cut down and the trees were cut into approximately 2’ lengths. Most are about 6-8” in diameter. They are about two years old at this point.
I’m thinking that I want to slice these into slabs and let them air dry. I know I won’t get that much wood for projects, but since I do a lot of small stuff – it might be worth my time.
I am wondering what would be the best way for a person without a mill to do this small stuff. The smallest stuff, I know I can use a sled on the band saw to cut. Since I don’t have a riser, I’m limited on size.
For the bigger stuff, does it make sense to use a wedge and a sledge hammer to split the log and cut from there? As I recall from splitting logs when I was a kid (only two or three years ago——- yeah right!) that the logs generally split pretty cleanly along the grain.
What suggestions do you all have?
Thanks in advance.
-- Betsy - GO BUCKS!
View dalec's profile
dalec
458 posts in 369 days
116 days ago
What is the max cutting capacity of you bandsaw?
Dalec
Betsy
116 days ago
It’s a 14” Jet, no riser – so about 5.5” is what I’m comfortable with.
View frank's profile
frank
1384 posts in 687 days
116 days ago
Hello Betsy;
—-hmmm, first thought is; what is the species of wood your talking about here?
—-second thought; I imagine your not thinking about using a chainsaw?
—-third thought; you could always rive the log, if the grain pattern is running straight….
....and….
....plus….
....and I did do a blog on this some weeks ago, about riving with froe and mallet.
But then these are my ways and only ‘two cents’ worth of opinion….
Thank you.
GODSPEED,
Frank
Hmmm again, and yes that is snow in the background of that first picture….seems like that blog story was//is more than a few weeks ago….LOL….
-- --frank, NH, http://frank.wordpress.com/
dalec
116 days ago
After looking at the cutting capacity of your bandsaw, it looks like you will need to split the rounds. I suppose you could do it like Abe Lincoln by driving a series of wedges along the grain to split the round down the middle, so you will end up with to half round with 1/2 the thickness of the original. You will need to have something that hold the round from moving on you while you drive the wedges. Work slow and don’t over do it and you should get there.
Or find someone with a bandsaw with a riser who is willing to cut the slabs for you.
Dalec
View John Ormsby's profile
John Ormsby
157 posts in 218 days
116 days ago
You will get better, straighter, and stronger wood for furniture if it is split to naturally follow the grain such as with a froe. Then let it dry and flatten it with the jointer and then planer when ready to use.
-- Oldworld, Fair Oaks, Ca
Betsy
116 days ago
Thanks for the suggestions guys. Frank – I’ll check out your blog.
I’ll probably try to find someone with a riser for some of the nicer logs and try the splitting with wedges myself on the others. The splitting will have to wait until I’m completely healed from the car accident – but this at least gives me the ideas I need to work with.
thanks again.
View Dorje's profile
Dorje
1743 posts in 478 days
116 days ago
In addition to splitting the larger ones, consider this: you don’t get too much of a board from the outside of the log, so you could chop away a flat spot on opposites sides (or even just on side), and then plane at least one of them flat for a reference surface. Doing this, you’ll get wider boards than if you chop the log in half (in the center)...and you can get the max out of what you’re comfortable with on the bandsaw.
dalec
115 days ago
Good point Dorje
Dalec
View trifern's profile
trifern
3967 posts in 248 days
115 days ago
Frank, you are da man.
-- Depend on the rabbit's foot if you will, but remember it didn't work for the rabbit.
Bookmark And Share This Page
