New 14” Jet band saw question
Forum topic by Mike Kemper posted 532 days ago 282 views 0 times favorited 6 replies Add to Favorites Watch
View Mike Kemper's profile
Mike Kemper
52 posts in 708 days
532 days ago
I just finished assembling my new Jet 14” Band saw with the riser block. went toghter real easy with some help. I also bought a ¼” Timber Wolf blade. I thought I would install the Jet blade that came with the riser block assembly for practice. The problem I have is the blade seems to be to short and won’t go around the wheels; I completely released the blade tension. Does anyone have a suggestion?
View GaryK's profile
GaryK
9536 posts in 885 days
532 days ago
I’m pretty sure that the blade should be 105” for the Jet. You should measure it to be sure. Just start from the weld.
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 712 days
532 days ago
I have that saw with the riser. It is a 105.
HTH
View Dano's profile
Dano
217 posts in 929 days
532 days ago
I have the same set up and have had some problems like you mention. It will fit but the best I remember I had to start the blade on the wheel and then roll it on by turning the wheel by hand. It is a tight fit, I also suggest you invent some new words while working on it. They won’t help the fit but they seem to help your attitude.
-- Dan in Central Oklahoma, Able to turn good wood into saw dust in the blink of an eye!
View Doug S.'s profile
Doug S.
306 posts in 605 days
532 days ago
I used to have a 14” Jet+riser but sold it about 3 years ago. If I recall I had a similar problem after installing the riser. I think I had to loosen up the top wheel to get the blade on. Not the tensioner (tho that needs to be as loose as possible too) but the one on the back side #91 on the parts diagram http://woodworking.jettools.com/PartDetails.aspx?BDID=409
then readjust after getting the blade on.
-- Use the fence Luke
View motthunter's profile
motthunter
2079 posts in 696 days
532 days ago
First, it is a 105 blade.. second, you will have to loosen to lower the top wheel to get the blade on. I had the same challenge with my powermatic. Powermatic is the same saw but comes with arter guides and tension system.
-- making sawdust....
View Al Killian's profile
Al Killian
271 posts in 650 days
509 days ago
Any chance of getting a blade that is a 1/2” longer? This would give room to slide it on and adjust it? Not sure if this would work, but maybe a good solution.
