| Forum topic by KoiGuy | posted 447 days ago | 2658 views | 1 time favorited | 24 replies | ![]() |
447 days ago |
Topic tags/keywords: drill press question chuck falling out I have a continuing problem with my Craftsman Drill press. The chuck falls out! It’s old about 20+ years and has always happened but seems to be getting worse. I have read several forums on this and they are often contradicting either by saying clean with a solvent or not and by lubricating or defiantly not lubricating. One even says sand lightly. While all this is easy on the shaft it’s next to impossible to get up inside the receiver. It Leaves me frustrated and wondering if there is a better way to fix this problem so I can get through a project. |
24 replies so far
#1 posted 447 days ago |
If it’s 20+ years old and has been happening repeatedly over the years I would tend to believe the taper and the quill are worn out from slipping. -- Improvise.... Adapt...... Overcome! |
#2 posted 447 days ago |
I can share how I cleaned and installed the Morse Taper in my Rikon radial press. First, I simple-greened it to remove all packing grease; using paper towels on dowel to get the inside. I then used renaissance wax on the taper and the inside (you will only need 1 can per lifetime). The inside I applied using two microfibers on a scrap dowel, one cloth fairly loaded; the other clean for buffing (I use a dedicated pair for my machines). I use this wax everywhere except for moving metal-on-metal contact (gears); since this should remain seated I didn’t use machine oil here. I expanded the chuck so the teeth are not exposed, just the outer lip. I then got a big soft chunk of pine, and a dead-blow mallet. You can probably guess the next step… or twelve. :) Mine has been good to go since the first seating, and will stall out the belt pulley before that link slips. Welcome to LJ, and good luck getting yours squared away. -- Chris @ Atlanta - JGM - Occam's razor tells us that when you hear hoofs, think horses not zebras. |
#3 posted 447 days ago |
http://www.youtube.com/user/capneddie/featured -- bill@magraphics.us |
#4 posted 446 days ago |
Since the Morse taper is a friction fit how does the lubrication help? -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#5 posted 446 days ago |
Thanks guys! I’m a little confused on wax? Seems that would be a lubricant? I’m going to try without first. And Bill I couldn’t find Eddie’s video on this. If you have another link than the Youtube link I’d love to have it. This is a picture of my chuck it has a JT3 stamped on it. I guess this means Tamper 3? It is a little scratched up should I be concerned about getting all these out? Any help would be greatly appreciated. |
#6 posted 446 days ago |
Actually, JT# is a Jacob Taper #3. Actually, now that I think a little harder about this, the JT# taper is the taper that is holding the chuck on to the arbor. What is the diameter of the taper that keeps slipping out at the top and the bottom? Mike |
#7 posted 446 days ago |
KoiGuy, look at this. -- bill@magraphics.us |
#8 posted 446 days ago |
How do I know if it is supposed to be a MT3? Is there a marking somewhere? This is the one that came with the drill press. You would think it’s the correct one, can you tell by looking up the receiver? |
#9 posted 446 days ago |
Hey Koiguy- I have a very humid location and have rust problems without waxing everything. I even use it on visiting relatives and friends. Like you’re planning, I would go with the advice of the more experienced folks and perform the install (of the correct chuck) without anything on the mating surfaces. I’ve experienced no issues, but then again I took special joy in the seating process and could have gotten lucky. Good luck, -- Chris @ Atlanta - JGM - Occam's razor tells us that when you hear hoofs, think horses not zebras. |
#10 posted 446 days ago |
Thanks Bill that is a neat little tool and I will invest in that as soon as I find out if I have the correct arbor. And thanks Bagtown I will be interested in knowing if Sears gave me the wrong arbor 20+ years ago. I wonder if I could take it back now and demand the correct one? ITnerd that is very interesting that yours works with the wax. You would think it wouldn’t. Yes it is very humid in Atlanta but we can have a fare amount her in Kansas as well. Good luck waxing those relatives. |
#11 posted 446 days ago |
A couple of things: From the two pictures, it appears you have the correct taper for your machine. I always learned to never wax or lube friction fit. The JT taper you show in the photo looks like it is burnt or galled near the top (Chuck end). If it is, it was slipping, but if you sand it down it will be too small and make the fit worse. What model is this press? It might help someone with more experience than I have diagnose the problem. -- Improvise.... Adapt...... Overcome! |
#12 posted 446 days ago |
Thanks Dallas by FOD I think you mean foreign objects? I don’t know if I’m getting it lined up this is the first I’ve heard of the slot and key. I would appreciate any and all info on this. I have found my owners manual finally and to my surprise I bought it in 1996 for $288. It’s a Model No.113.213151 a 15” Floor Craftsman. In the manual it shows installing the chuck onto an already in place arbor which I did back in 96 and it also shows a Wedge key that I don’t see anywhere. Maybe this is the missing Key, pun intended. You can see in the diagram. |
#13 posted 446 days ago |
Here ya go…. -- Improvise.... Adapt...... Overcome! |
#14 posted 446 days ago |
So it appears I am missing a wedge key. So that’s what really holds it in? This makes more since to me. I have no idea what happened to it or if it was ever there. It’s amazing it’s worked at all without it. It looks long in the diagram like it won’t fit in there are we sure it stays in there? |
#15 posted 446 days ago |
I think the wedge key (or Drift key) is used to remove the arbor. I have one and it is in a drawer in my tool box, I’ve never used it. -- Close to Ottawa Ontario Canada |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6134 |
