Forum topic by albachippie | posted 03-29-2012 06:40 PM | 10941 views | 0 times favorited | 17 replies | ![]() |
Topic tags/keywords: help table problem bandsaw I bought a second hand, but still boxed and unused, DeWalt 876 bandsaw back in October. With work and general life busyness I’ve only now got round to setting it up. Set up was great, and surprisingly straight forward. I did the usual test cuts of random wavey lines with great new tool enthusiasm! All was good! Then, I did a rip cut using the fence, through a 3”sq piece of pine. Again, all seemed great, untill I checked the fresh cut for square. Well, it wasn’t! Square I mean. The blade was sitting perfectly square to the table, and the fence also was square to the table. The problem is that the extruded alluminium table, when you put a straight edge along the surface, is far from flat, in any direction. The scale running along the front of the table doesn’t lie flush with the table either, which means the fence is following the variations in the table rather than sitting against the scale. The photos give an idea. The new(ish) saw! Straight(!) edge The scale which should run flush to the table The saw itself runs and cuts well. I really like it, and, at £250 still think it was well worth it. It’s just frustrating that there is this manufacturing fault with it. Can a new table be made? What would the drawbacks Once again, any advice appreciated! Thanks in advance, Garry -- Garry fae Bonnie Scotland |
17 replies so far
#1 posted 03-29-2012 06:50 PM |
That’s a real drag. I’ve actually never seen this particular saw before. I think a simple table build is probably the way to go. You could probably salvage the rails and if you need a new fence, so be it. If the saw runs and cuts well, I think you’re doing pretty good. I had a DeWalt circular saw once with a twisted plate. I guess it happens:) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#2 posted 03-29-2012 06:57 PM |
You can sand the table flat on a sanding board but that will |
#3 posted 03-29-2012 06:58 PM |
Try shims first. See if ya can pull it flat. -- bill@magraphics.us |
#4 posted 03-29-2012 07:03 PM |
I have found that I usually use a bansaw for rough shaping curves, trimming bark off rough lumber etc. In these cases the tablesaw or router table will cut the finished edge for my project. So in some ways it may not matter. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#5 posted 03-29-2012 07:09 PM |
It’s not so bad buddy, there are ways to fix this! No reason to fret. There are a few ways to go about this. The method I used on a scroll saw of mine and my buddies bandsaw is a very permanent method, though there are others that are more temporary. The easiest solution is to add a new top over the existing top using a piece of phenolic coated plywood. Simply use machine screws in counter-sunk holes to bolt it right down. You can mill yourself a new miter slot in the ply if you choose as well. It’s best to shim under the ply where the table dips, this will keep the ply from sagging. What I did for myself and my buddy, was to use Devcon’s Liquid Aluminum and Aluminum Putty and built the table back up to level. You could also use a product like USC’s All-Metal body filler. You will need to scuff your table well with 100-150 grit paper to assure good adhesion. Then build the lows up using the putty and skim-coat the entire table-top with the liquid. Now, once the Devcon has dried, use a long, flat sanding block to level the surface so it’s dead flat. Now, you will have a solid and dead-flat table top that isn’t going anywhere. You could also fill the lows with Devcon and then add the phenolic coated ply over this. Or you could substitute a piece of aluminum plate 1/8” to 1/4” thick, obviously leaving the miter-slot exposed. There are many ways to fix this. But I would advise against trying to pound the table flat in any way. Aluminum is brittle and may crack. Good luck. -- Kenny |
#6 posted 03-29-2012 07:13 PM |
#7 posted 03-29-2012 07:43 PM |
Garry – Before you do anthing else, contact Dewalt and tell them the problem. I bet they send you a new table FOC. I’ve got a Dewalt chop saw and one of the knobs wasn’t drilled straight. I phoned them up and they just sent me a new one FOC. I have a Dewalt router, which came with a 1/2” and 1/4” collet. They were interchangeable except for the fact that I couldn’t get the 1/2” collet out of the nut for love nor money. I phoned them up and the sent me another nut FOC to use with the 1/4” collet. I you don’t ask, you don’t get. It is in their interests to keep you sweet. -- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it." |
#8 posted 03-30-2012 08:04 PM |
Hi Guys, Thanks for the abundance of advice! Bertha – I think I will try and make a new overlay table, or maybe complete new one. I like the idea of the challenge! Loren – I hadn’t thought of sanding. I guess I could recoat it with a metal laquer. Not sure about the panel beating approach! Don’t think I have the finnesse for that! Bill – shims will be my first stop after DeWalt reply Pinto – I intend to do bandsaw boxes eventually, so the table will require a flatter surface than now. You’re right though, it’s more the fact that I know it’s not right, and I want it to be right! Kenny – wow! Ididn’t know such a thing existed! This stuff looks amazing. I’d love to give it a go. Thanks so much for your comprehensive reply, and links. Much appreciated. Thanks again friends for your advice and encouragement. I’ll let you know the outcome, Cheers, -- Garry fae Bonnie Scotland |
#9 posted 04-09-2012 02:04 PM |
Well, as I suspected, DeWalt aren’t interested in helping with a second owner machine. So, I think i may have to get myself sorted and make my first tool table! Thanks again for all the advice guys, Garry -- Garry fae Bonnie Scotland |
#10 posted 04-09-2012 02:58 PM |
wont they sell you a new table. It seems like out the door and forget about. customers problem, -- Chuck, wiswood2 www.wisconsinwoodchuck.com |
#11 posted 10-22-2012 03:48 PM |
Hi there! Personally, I had one DW876, and cant really recommend this band saw to anyone! Lost hours and days trying to get it running ok, and one or two days later, it needed attention again! Took it apart 2 times, spent a lot of money buying parts, and it was the saw itself that its not that great! Sold it and bought a makita LB1200F. It has 165mm max height vs 200mm on the DW,but has been a trustable compannion in work, and doesnt require such as much attention as the Dewalt. Maybe my DW had factory deffects or so, i dont know! However, never seen Dewalt machines has great working horses….dont think their products are Top quality, just a bit over Black and decker, and twice the price. |
#12 posted 10-22-2012 06:26 PM |
Goodness, I had forgotten about this post! After spending quite a lot of time stripping down this saw and resetting, I got it running really sweet. I am able to resaw oak with relative ease. The fence needs reset after each blade change, but that is par for the course on any b/saw. The table remains warped, but I have made a veriety of overlays for different tasks, which work well. I have bought some blades from Tuff Saws, which are pretty good blades. I have not found any problems in sourcing blades. Most companies manufacture blades to order anyway, so any length is fine. I also changed the guide blocks for some hardwood ones. These work particularly well with narrow blades, and stop some of the squeal and heat problems. The tensioning is a bit hit and miss, but once you get a feel for the blade being used, and learn to completely ignore the tension scale!, all works well. All in all, I think I got a bit of a bargain with this saw, and I am pretty pleased with it. That said, I am very glad I didn’t shell out for a brand new one. I would have been sorely dissapointed with it if I had. As for DeWalt as a brand, I have many DeWalt tools, and have no complaints. They are not the best quality, but I do think, on the whole, they are very good value for money. -- Garry fae Bonnie Scotland |
#13 posted 10-22-2012 06:52 PM |
I’d take it to a machine shop and have it ran thru a surface grinder. -- Life is good. |
#14 posted 10-25-2012 10:11 AM |
Sorry if offended you in any way, about the brand or the bandsaw itself, if so didnt intend to do it. I have other Dewalt tools too, and like them a lot, like a dw625 router that I just love and to this date, never found a better router then this one, to suit my needs! I guess we cant stick to a brand only, gotta find the best choice in the category we´re buying. In smaller bandsaws, like the 2 I´ve worked with (DW876 and the Makita lb1200f), my choice goes for the makita, not because the trouble of the DW I had, but is soo much smoother and accurate, better quality construction, nice features too, and yet so far, trouble free.Has lateral bearings to support the blade, wich is not very common on this smaller bandsaws, and the Led lights sure are great!! Also very easy to move arround the shop when needed. Good Woodworking and all of the best! |
#15 posted 10-25-2012 12:42 PM |
Trust me, I’m not that easily offended! Sorry if that’s what came across. I have no loyalties to any particular brand. Much like you say, I buy what suits my purpose and budget at any particular time. I’m glad the Makita is working out for you. I have their big router, forget the model at this moment. It’s a great machine and has served me very well for many years. Cheers for now, Garry. -- Garry fae Bonnie Scotland |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
