How should i apply fence stain?
Forum topic by brantley posted 03-29-2012 05:13 PM 5755 views 0 times favorited 7 replies Add to Favorites Watch
View brantley's profile
brantley
185 posts in 3221 days
03-29-2012 05:13 PM
Topic tags/keywords: question fence stain
I am trying to figure out how i should apply a weather proofing stain to my fence. I live in a small town and none of the tool rental places rent out sprayers. WIll a brush and roller work? I know it will be labor intensive but i dont mind that. For the most part i was wondering how much more stain i will go through by rolling/painting as opposed to spraying? Im assuming i would go through much more but the guy at the paint store told me it would be about the same? Thought i would get some input here. THanks
7 replies so far
View joebloe's profile
joebloe
157 posts in 2257 days
#1 posted 03-29-2012 05:35 PM
you could use a pump up sprayer,less labor but I think it would take more sealer.
View dhazelton's profile
dhazelton
2754 posts in 2260 days
#2 posted 03-29-2012 06:04 PM
It would help to know what material you want to use and the type of fence, picket or more of a solid privacy fence…
If it’s a penetrating transparent stain you can use a pump sprayer. and probably won’t waste much. If it’s a solid body stain that’s latex based it will be thicker and you can easily roll it, but then you have to catch the edges with a brush if it’s a close picket style. Easiest to do is have two people, one on each side, and you can catch each others runs and misses. Won’t seem so daunting either. Also a lot depends on how dry the wood is.
View Manitario's profile
Manitario
2629 posts in 2846 days
#3 posted 03-29-2012 06:05 PM
pay a student to do it for you….
brantley
#4 posted 03-29-2012 06:44 PM
Stain is from Benjamin Moore paints. Pratt and Lambert is the brand. I am going with a semi transparent.
brantley
#5 posted 03-29-2012 06:45 PM
Pine dog eared picket fencing
View Jim Finn's profile
Jim Finn
2647 posts in 2885 days
#6 posted 03-29-2012 10:05 PM
I would put it on with a roller on a 6 foot long pole. I did my privacy fence and started with a pump up sprayer and there was too much over spray onto the concrete driveway. I went to the much more controllable method of using a roller.
-- Website is https://craftingcouple.com/
dhazelton
#7 posted 03-30-2012 09:09 PM
He still has to paint the edges of the pickets. He needs to brush as well as roll. If the pickets are spaced very openly you may be able to get a hot dog roller between them.
