Blast Gates for dust collectors...suggestions?
Forum topic by Lormax posted 03-29-2012 04:45 PM 9106 views 0 times favorited 11 replies Add to Favorites Watch
View Lormax's profile
Lormax
2 posts in 2273 days
03-29-2012 04:45 PM
Hello all. I’m new here, though been reading a number of posts on the forums as I setup my garage for woodworking. I’m at setting up the dust collector, which I purchased at Harbor Freight (the 2hp version). What I was wondering…which blast gates are most of you using? I was getting ready to order some…found some black plastic 4” ones on Amazon, though the reviews weren’t too enthusiastic about it. The issue the reviews focused on was that the gates would end up getting clogged with chips and dust, preventing the gate from closing fully. One suggested the metal gates, though there are so many products out there, I’m not sure which to go with.
So that brings me to my main question…what to order? I’d rather not have to take apart my dust collection ducting every few months to clean these things out. Lets assume price isn’t a major factor…usability is. Thanks for any suggestions!
11 replies so far
View oskarman's profile
oskarman
30 posts in 2334 days
#1 posted 03-29-2012 04:54 PM
i got the self-cleaning blast gates from Lee Valley….they’re great and easy to install. i would absolutely purchase them again.
http://www.leevalley.com/US/wood/page.aspx?p=51506&cat=1,42401,62597
View SugarbeatCo's profile
SugarbeatCo
142 posts in 2292 days
#2 posted 03-29-2012 04:56 PM
I use the metal blast gates from rockler, with the screw facing the upsteam side, and they work pretty good. The fitting is really small which makes the install
a pain, but once set up theyre great. Rockler also sells little wall mounts too
-- Always one more tool away from being an excellent woodworker...
View Scot's profile
Scot
344 posts in 3420 days
#3 posted 03-29-2012 06:11 PM
I use both the metal and plastic blast gates with no issues with either. I watch for them on ebay and catch some good deals on them.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
Lormax
#4 posted 03-29-2012 07:15 PM
Wow, very fast responses, thanks! I’ll look into both the Lee Valley and Rockler ones. Ebay gets checked first, thanks Scot :)
View Elizabeth's profile
Elizabeth
817 posts in 3167 days
#5 posted 03-29-2012 07:50 PM
I got the metal ones from Woodcraft; I think they’re the same as Rockler. Careful which way round you install them; I found out after the fact that it’s possible to do it backward! (Knob goes on side toward the machine, not toward the collector.)
View pmayer's profile
pmayer
1028 posts in 3089 days
#6 posted 03-29-2012 11:45 PM
I buy my 4” gates from these guys: http://www.blastgateco.com/. Cheap, really good quality, and great service. I will never buy the cheap plastic ones any more.
I used to by my 6” gates from there as well, but now I use Clear Vue. If CV had 4” I would use those as well, but for now they only carry 6”.
View John Ormsby's profile
John Ormsby
1288 posts in 3760 days
#7 posted 03-29-2012 11:56 PM
I agree with Oskarman about the Lee Valley blast gates. I have them on my system and have never had any problems with them. They are the highest quality gates on the market. The flex hoses fit very well and they operate smoothly.
They are designed to always clear any sawdust from jamming the gate.
-- Oldworld, Fair Oaks, Ca
View AandCstyle's profile
AandCstyle
3069 posts in 2281 days
#8 posted 03-29-2012 11:59 PM
Lormax, depending on your setup (number of attached machines, total run of tubing, bends in the tubing, etc) you may find that 4” is not sufficient to do the job. The wall of the tubing creates turbulence or drag and you may find that you are not able to get adequate CFM through a 4” tube. Go to Bill Pentz web site for everything you ever wanted to know about dust collection.
HTH,
Art
http://billpentz.com/woodworking/cyclone/index.cfm
-- Art
View woodman88's profile
woodman88
144 posts in 2672 days
#9 posted 03-30-2012 01:47 AM
Rockler has their steel ones onsale right now
View TechRedneck's profile
TechRedneck
768 posts in 2881 days
#10 posted 03-30-2012 02:42 AM
Metal self cleaning good….plastic cheap ones…suck. I have both, I will never get the plastic ones again.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View Boxguy's profile
Boxguy
2682 posts in 2291 days
#11 posted 03-30-2012 03:09 AM
Most any gates work with fine dust, the problem I have is with bigger chips that come from planers and routers. Though it lets some air leak when it is open, cutting off the bottom of the gate slide slot so the slide can stick through the bottom makes them self cleaning as you close them. The descending slide cleans out the side groove and nothing collects in the now open bottom of the gate.
You can also make a gate out of a damper valve if you are dealing only with fine dust. A damper valve is a circular metal disk that spins inside the pipe and is operated by an external lever. Turn it sideways to seal the pipe and spin it 90 degrees to open the gate.
-- Big Al in IN
