Metal Lathe vs. Wood Lathe
Forum topic by beaudex posted 534 days ago 2262 views 0 times favorited 4 replies Add to Favorites Watch
View beaudex's profile
beaudex
43 posts in 537 days
534 days ago
Topic tags/keywords: turning lathe
This is a question for you guys out there who also have some machinist training out there. I may have the opportunity to pick up a metal lathe for a very decent price (cheaper than a wood lathe). I currently do not own a lathe nor have I ever used one an so I am wondering a couple of things:
1. Can you easily use a metal lathe for wood?
2. Would I also be able to use the lathe for metal at the same time I was using it for wood?
3. Would I need to have accessories made for the lathe i.e. a tool rest or would the stock lathe suffice?
4. Could using the metal lathe for wood damage it for using it on metal?
I would appreciate any suggestions you may have on this issue.
Derek
-- Derek Tay, Venerate the Tree Design
View GaryK's profile
GaryK
9539 posts in 887 days
534 days ago
I have both one metal and two wood lathes.
There’s no reason you can’t use the metal one for wood. I do. It’s perfect for getting things exactly the same.
questions:
1. yes
2. not at the exact same time :-) otherwise yes.
3. yes, a tool rest. Depending on what is there already.
4. no.
View Blake's profile
Blake
2763 posts in 773 days
534 days ago
I don’t have hardly any turning experience. But when a very small metal lathe came into our tool shop I decided to “test” it out. I turned these:
Click for details
The thing about using a metal lathe is that it is like using an Etch-a-Sketch to turn wood (you don’t hold the turning tool by hand). There is an X dial and a Y dial that move the tip and it takes quite a bit of unnatural coordination. It makes some things easy (like making a perfect barrel) and some things harder (like natural seeping curves). But it can be done!
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 611 days
533 days ago
I also had wondered if it was possible to use a metal lathe for WW. Now I know, good question, good answer!
View Alin Dobra's profile
Alin Dobra
316 posts in 786 days
532 days ago
Derek,
Essentially, a metal lathe is a “programmable” lathe but the wood lathe is not. What I mean by that is that you have mechanical help in describing a trajectory for the cutting head, without the need to hold the tool in your hand.
Advantages of metal lathes:
1. You do not need a very steady hand or a very strong grip to machine any material, no matter how hard
2. You can machine perfect (simple) curves. For example, a perfect cone or cylinder
Disadvantages of metal lathes:
1. Expensive
2. Much lower capacity (swing over bed) than wood lathes
3. Complicated machines. Too many things to worry about
The wood lathe is a lot more appropriate for artistic work, in which you do not want to work with a prescribed shape but to follow your instinct. For example, it is fairly hard to do a perfect cylinder or a sphere (you basically need jigs to do that), but the turning is a lot more straightforward. I almost never think about the shape when I turn wood, I just do along with the “feeling”.
I can see two ways to use a metal lathe to turn wood:
1. Do what Blake did and play with the X-Y controls to get a shape. While it will work to some extent, the shape will be choppy (unless you have extraordinary skills).
2. Retrofit the metal lathe with a tool rest used for a wood lathe so you can use it like a normal wood lathe (not sure if you can find such a toolrest).
Unless you are very space constrained, I would strongly suggest you buy a wood lathe and a metal lathe. It is very likely that the metal lathe will cost you 5-10 times more than the wood lathe of the same capacity. If you are unsure you want to do a lot of metal work, go with the wood lathe for now.
Alin
-- -- Alin Dobra, Gainesville, Florida
