How to create a long "tabletop" for a built-in
Forum topic by insboswiz posted 03-28-2012 08:22 PM 1712 views 0 times favorited 8 replies Add to Favorites Watch
View insboswiz's profile
insboswiz
3 posts in 2246 days
03-28-2012 08:22 PM
I recently built a combination bookcase/base cabinet built-in for my wife. The design is pretty simple – a pair of base cabinets topped by a piece of plywood tabletop (with hardwood edging), itself topped with a pair of bookcases. It worked our fairly well and now my wife wants a larger one for our main living room.
The question I have is how to create the “table top” portion. When I built the one upstairs, the whole thing was less than 8 feet long, so I used a single piece of plywood for the tabletop. I’m not going to be able to pull that off downstairs however as the length of the built-in is going to be longer than 8 feet, so a single piece of plywood is not going to work.
I’ve seen built-ins that are fairly long and they don’t seem to have seams in the tabletop portion. I was wondering how one creates something like this that would run for maybe 18-20 feet, yet not show any seams where boards were joined. I believe the project will end up painted rather than stained.
Any help would be most appreciated.
8 replies so far
View rustynails's profile
rustynails
747 posts in 2524 days
#1 posted 03-28-2012 08:27 PM
Use a piece of nova-ply or MDF and veneer it. I know you can get the nova play in longer lengths but I am not sure on the MDF.
View cabmaker's profile
cabmaker
1730 posts in 2804 days
#2 posted 03-28-2012 08:33 PM
If its going to be painted we probably dont even have a discussion here. If your staining you can use 10 ft ply or exercise judicial joinery. Plywood can be matched for grain to some success and , or place your joints away from the ctr. Joints can be placed at the upper cabinet transition which will hide some of it. Hard to know what to do without seeing what your building, but I know this, it is doable. JB
View Sawkerf's profile
Sawkerf
1730 posts in 3064 days
#3 posted 03-28-2012 08:42 PM
That’s gonna be a real challenge. Even if you can make a one piece top that long, would you be able to get it into the room and on the bases?
I built this for a customer a couple of years ago. Her condo was on the fourth floor and everything had to fit in an elevator.
The wall was a bit over 11’ long and I made the top in three sections – each banded on the front and both sides. The seams just butted together and I put them under the sides of the bookcase sections to minimize their appearance.
Maybe something like this would work for you.
insboswiz
#4 posted 03-29-2012 01:09 PM
Thanks for the ideas so far. Below is a pic of something close to what I’m trying to achieve. The difference in my design is that the flat surface that separates the bottom cabinets from the top bookcases will protrude about 6” – 8” in the front, so any end to end joins can’t be completely hidden by the uprights for the bookcases.
Sawkerf
#5 posted 03-29-2012 02:13 PM
My joints weren’t invisible – just as unobtrusive as I could make them. Why so much overhang for your top?
insboswiz
#6 posted 03-29-2012 03:21 PM
Wife likes the look. She had a friend once who had such a construction. I can probably show her the picture above and talk her out of it.
Sawkerf
#7 posted 03-29-2012 11:27 PM
I like my tops to extend by a bit more than whatever is beneath them. I generally like 1-3/4” – 2” which “covers” doors/drawers plus pulls/handles.
View bruc101's profile
bruc101
1200 posts in 3537 days
#8 posted 03-31-2012 03:41 AM
I built a 12 foot oak wall unit about 6 years ago and used 3/4 oak ply for the top. I took some time to find two pieces with some of the same grain figure in it. When I felt like I was close enough I used a solid surface wavy router bit on two ends with the least amount of wavy grain showing.
I glued the two pieces together and the wavy router bit made for a dead on fit of the two pieces of ply.
Once the top was ready I then mixed some dye the color the top would be and worked a small area around the seam. The lady had picked out a Minwx stain and when I stained the top it was very difficult to see the seam especially after 5 coats of satin clear lacquer was sprayed on it.
I use this method on any long ply tops I make and have excellent results.
-- Bruce Free Plans http://plans.sawmillvalley.org
