What is "dry"?
Forum topic by AndyB posted 448 days ago 600 views 0 times favorited 7 replies Add to Favorites Watch
View AndyB's profile
AndyB
12 posts in 818 days
448 days ago
Topic tags/keywords: pecan moisture table tops milling question
My local wood yard has some 6/4 pecan that is air dryed to a moisture content of 17%. This was made from a surface measurement and not a core. Although the supplier assures me that this moisture content is ok, I have my doubts especially as the boards will be used exclusively for six table tops and will have to be milled to around 4/4. I have always assumed that wood moisture should be in the range of 8-12%.
-- Andy, Texas, http://www.boglewoodworks.com
7 replies so far
Rick Dennington
2893 posts in 1392 days
#1 posted 448 days ago
AndyB:
Don’t listen to that guy…the moisture content is way too high, and the wood is still too wet….It needs to be about 6—7 %......8—12% is still a little too high in my book….If you get wood in that 17 % range, the wood will twist, bow, cup, or whatever…..Buy wood with the lowest moisture content you can find…...buy kiln dried wood, if possible….
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
View pintodeluxe's profile
pintodeluxe
1852 posts in 1011 days
#2 posted 448 days ago
You can dry wood from 15-17% down to 6-8% in two weeks with a home dehumidifier, some fans, and a heater. Interestingly, wood will never get dryer that about 15% when stored outside or in a barn.
(of course this can vary by location ie: Arizona etc)
If you don’t have a means to dry the lumber yourself, I would buy kiln dried lumber.
View WDHLT15's profile
WDHLT15
715 posts in 674 days
#3 posted 448 days ago
In Georgia, air dried pecan will equilibrate to about 14% moisture content when air dry. In use moisture content in this climate will be 9 – 10% moisture content. So wood at 17% moisture content here will shrink some from your 17% to 10%. Like has been posted, ideally, you should bring it inside and let it dry in a climate controlled environment for about a month. I did a test on air dried oak. I skip planed it to 7/8”, brought it inside last March and stickered it behind the couch. It began at 13.5% moisture content. I noted the moisture content on the top boards of the stack with a pencil, and continued to measure the moisture content periodically. After 3 weeks, it reached 9.8%, and it stayed that way until August when I finish planed it and installed it as waisncott in a bathroom.
-- Wood-Mizer LT15
AndyB
#4 posted 448 days ago
I have got several stacks of oak that have been air drying in a barn (we are in Texas) for about twelve months and it has got to an average moisture of 10%. I always bring this wood into my air-conditioned workshop and let it acclimate for a month or so before using it and have had good results. Unfortunetly I don’t have the luxury of time with the pecan. I appreciate your comments and it looks like I’ll have to make the three hour round trip into the big city to pick up a load of kiln dried lumber! One question for WDHLT15 – what is “skip planing”?
WDHLT15
#5 posted 447 days ago
Reducing the thickness without making sure that each face is perfectly smooth. Skip planing gets the wood flat, but is an intermediate step. You can call it partial planing. Reducing the thickness reduces the drying time.
-- Wood-Mizer LT15
View HalDougherty's profile
HalDougherty
1820 posts in 1435 days
#6 posted 447 days ago
http://ir.library.oregonstate.edu/xmlui/bitstream/handle/1957/5190/Moisture_Content_ocr.pdf
Here’s a pdf file that explains how to determine the moisture content of your wood without a moisture meter. It’s also a more accurate way to calculate moisture content than a meter. 17% is a very good starting place to air dry wood before it’s kiln dried. I air dry my lumber to somewhere below 20%. In East Tennessee it takes about 30 days when the weather is 80 degrees or warmer. Then I move it to the 2nd floor of my old two story farm house. (I can dry a little over 500 bft without too much weight on the beams. It takes another 30 days to get between 6 – 12%.
After air drying, I plane the wood before I move it inside. WDHLT15 is right, it dries quicker after it’s planed.
-- Hal, Tennessee http://www.first285.com
View treaterryan's profile
treaterryan
100 posts in 485 days
#7 posted 447 days ago
Conditions in most of the US limit drying to about 12% (slightly less for hot, arid areas – 10/11%). Indoors in climate controlled conditions, you can get to your 8%. If you buy Kiln Dried Wood, pretty much anywhere under roof, except for straight out of the kilns, it’ll be in the 12-15% range. This wood is fine if you have a month or so.
The oven dry method, linked by HalDougherty, is an exceptional method for checking %MC. We use it for measuring %MC on industrial timber products at work. And for anyone’s future reference, the beloved moisture meter is simply are not accurate above 25%.
-- Ryan - Bethel Park, PA
