Incra miter 5000
Forum topic by Iggles88 posted 422 days ago 1280 views 0 times favorited 9 replies Add to Favorites Watch
View Iggles88's profile
Iggles88
203 posts in 533 days
422 days ago
Hey guys, I’m looking into buying the incra miter 5000. I want to take the plunge and order it but I can’t seem to figure out whether it is a miter gauge attached to a sled or all one piece. I know I’m going to want to use it without the sled and I don’t want to spend almost 300 dollars on just a sled. Thanks in advance.
9 replies so far
View EdwardR's profile
EdwardR
53 posts in 426 days
#1 posted 422 days ago
looking at this I would say all one
http://www.woodpeck.com/media/MG5000.pdf
View Bill White's profile
Bill White
2608 posts in 2132 days
#2 posted 422 days ago
Why not just use the 1000SE? This model has been a real addition to my TS. Don’t really know what the sled addition would bring to the game ‘cause I already have a sled.
Bill
-- bill@magraphics.us
View Jerry Bowen's profile
Jerry Bowen
9 posts in 440 days
#3 posted 422 days ago
The best way to get the straight scoop on your question is to go to Incra Tools on the web aqnd find tech support which will give you a phone number for Mark Mueller who knows all that there is to know about Incra products, he is a great guy and will answer all of your questions.
Jerry Bowen
Colorado City, Texas
-- Jerry's Stuff
View Eagle1's profile
Eagle1
2044 posts in 1236 days
#4 posted 422 days ago
I laso have and use the 1000SE. I use it for my TS and also my router table.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View GregD's profile
GregD
597 posts in 1308 days
#5 posted 422 days ago
I have the Incra 1000SE, and I also have the Incra Miter 5000.
The Incra Miter 5000 is a sled. The instructions state that the parts can be reconfigured to be a Miter 3000 (miter gauge) but this would be a rather significant hassle, IMHO. I also find that the practical cross-cut capacity is the distance from the front face of the fence to the front edge of the sled – 17” at 90 degrees I think rather than the 25” claimed on the web page. The protractor head and fence take up a lot of space. Wider pieces will hang off the front of the sled so there is no way that I can think of to clamp the work to the sled as one would normally do. Personally, I think I get better quality and more consistent cuts when the work is clamped to the sled.
The sled is very expensive for what it is, but boy does it work great, IMHO. With that long Incra fence you have essentially perfect positioning to the nearest 1/32 of an inch out to about 30” or so. I use a 1/4” dowel as the stop-rod and run that through the blade to zero it out. With this sled it does not take a great deal of skill to consistently get results more perfect than they probably need to be. As a hobbiest, I like that.
The Incra Miter Combo pack will give you a more versatile setup – a Miter Express sled and a Miter 1000SE. Moving the 1000SE into/outof the sled is simple. Probably exactly as good as the Miter 5000 sled but more limited capacity on the cross cut and fence.
-- Greg D. -- the price of freedom is tolerance
View KenBry's profile
KenBry
449 posts in 619 days
#6 posted 422 days ago
I have the 5000, I honestly Love it. It has worked well for all the crosscutting tasks I have used it for. Also I get some great angled cuts to any angle I need. Allot of what Greg said is true, so I won’t elaborate beyond what he said.
-- Ken, USAF MSgt, Ret.
Iggles88
#7 posted 422 days ago
I think if I went with the 1000 I’d get the 1000hd it has more stops and if I’m not mistaken is a newer model. That is a lot of the reason why I didn’t want the miter sled combo with the 1000se. I considered buying the sled and the miter 3000 but that’s getting really expensive.
View goethert's profile
goethert
17 posts in 379 days
#8 posted 335 days ago
I wonder what is your final choice after three months, 1000, 1000hd or 5000? Since I am on the same boat now. Why do you think the miter sled combo with the 1000se have problems?
Iggles88
#9 posted 335 days ago
I ended up with the 1000hd, it’s great…..the only thing I didn’t like was the shimming method. I didn’t say it had a problem I just think the hd is way better then the se more positive stops, they’re the same thing but the hd has stops at every degree.
