Matching solid walnut and walnut veneer
Forum topic by DavidBell posted 03-27-2012 08:51 PM 1851 views 0 times favorited 4 replies Add to Favorites Watch
View DavidBell's profile
DavidBell
2 posts in 2455 days
03-27-2012 08:51 PM
Topic tags/keywords: question walnut finishing
I am about to finish the wall unit in the picture. I would like to have the solid walnut frame match in color with the veneer walnut drawer fronts. You will see the frame is darker than the drawer fronts. I am hoping to keep the entire unit light in color. Is there a way to treat the darker solid wood frame so it does not get darker when finished. I would rather not have to bleach the dark pieces. Any ideas would be appreciated!!!!!
View Gene Howe's profile
Gene Howe
11072 posts in 3632 days
#1 posted 03-27-2012 11:14 PM
I would suggest not staining the solid and stain the veneer to match the solid. Use a scrap to test, of course.
View AandCstyle's profile
AandCstyle
3179 posts in 2461 days
#2 posted 03-27-2012 11:53 PM
You need to be careful staining some, but not all, the walnut. The unstained pieces will lighten with age and the stained pieces will not. You might try sanding the frame to a higher grit level so that it will not pick up as much stain as the plywood. As always, try everything on samples before committing to your actual project.
-- Art
117340 posts in 3781 days
#3 posted 03-28-2012 12:36 AM
I would use some of Charles Neils conditioner on both the the solid and veneered surfaces and then use a base of some General finishes water base golden oak dyestain, that will help even out the color , after that I’d use some GF water base walnut dyestain. If you have the know how I would spray it on . with the dyestain you can sneak up on it by applying a little at a time until you get the color you want. Just like Art said make sure you try it on a number of samples before working on the great looking built ins.
View Woodknack's profile
Woodknack
12431 posts in 2584 days
#4 posted 04-01-2012 08:46 AM
Yeah, use dye instead of stain so you can mix it weak to start and get there gradually.
