Charles Buck Chisels
« back to Hand Tools forum
Forum topic by KPW posted 449 days ago 1075 views 0 times favorited 5 replies Add to Favorites Watch
View KPW's profile
KPW
223 posts in 565 days
449 days ago
Topic tags/keywords: question chisel
I found these two chisels in an antique shop for a couple of bucks each. They are marked Charles Buck. One says cast steel. One is a socket type and has leather shock washers on the handle. Anybody know anything about them?
-- Ken --------- never try and put 5 lbs. of tenon in a 3 lb. mortise.
5 replies so far
View David Craig's profile
David Craig
2128 posts in 1305 days
#1 posted 449 days ago
Nice find . Before the name became Buck Brothers, the chisel company was just Charles Buck. I personally prefer socket chisels over the tang type. No real intrinsic value, but the steel is excellent and you have a couple high quality chisels for a great price.
David
View KPW's profile
KPW
#2 posted 449 days ago
Thanks David, That was what I was guessing and hoping for.
View KPW's profile
KPW
#3 posted 449 days ago
Does the socket chisel handle just friction fit into the socket? I’ve never owned one before?
David Craig
#4 posted 449 days ago
Yes, no adhesive is used. Pressure from using the chisel and mallet hits keep the handle in place. The cone shape where the handle seats in the chisel insures that, as wood shrinkage occurs, there is a wider point where it can be wedged in. If the handle ever needs to be replaced, there are some excellent blogs here on how to make a new one.
View KPW's profile
KPW
#5 posted 448 days ago
Great advice. Thanks. That must be why the handle doesn’t go all the way in. There is about a 1/8 ” of taper left when it seats.
