Trying to keep Aromatic Cedar from turning brown
Forum topic by getlostinwood posted 03-26-2012 02:30 PM 2331 views 0 times favorited 6 replies Add to Favorites Watch
View getlostinwood's profile
getlostinwood
224 posts in 2799 days
03-26-2012 02:30 PM
Any ideas on which finishes keep the reds and purples on cedar longer than a couple weeks?
-- The basis for optimism is shear terror
View Jim Finn's profile
Jim Finn
2686 posts in 3118 days
#1 posted 03-26-2012 02:39 PM
I use a clear acrylic spray on cedar. Lacquer works also.
-- No PHD just a DD214 Website> craftingcouple.com
View Charlie's profile
Charlie
1100 posts in 2482 days
#2 posted 03-26-2012 02:59 PM
Indoors or out?
I make flutes out of aromatic western red cedar. I rub them down with a 50/50 mix of citrus solvent and pure tung oil, then 25/75 (less solvent) and finally a 10/90 mix (very little solvent). If you want a higher gloss, rub them with beeswax and polish briskly with a soft cloth. I have flutes that are 3 or 4 years old and still have their color.
getlostinwood
#3 posted 03-26-2012 03:03 PM
Indoors, doing trophy mounts and have used lacquer on the front and sides, back is unfinished and after a couple months they are losing the brightness of the reds and purpilish hues. What kind of citrus solvent?
Charlie
#4 posted 03-26-2012 04:20 PM
citrus solvent…. uh… lemme see if I can find a link…
http://www.realmilkpaint.com/citrus.html
I use natural finishes for flutes mainly because people are putting their mouth on them. All my flute finishes are food safe. :)
It’s still quite a powerful solvent, but much safer to work with as we’re (woodworkers) generally exposed more long-term than the eventual owner of a single piece. We build lots of stuff. Less toxic fumes makes me happier. :) AND… it’s biodegradeable so no worries about disposal. (As long as it’s not mixed with something ELSE that may be harmful)
View jusfine's profile
jusfine
2422 posts in 3122 days
#5 posted 03-26-2012 04:30 PM
Would spraying or putting a finish on it seal it and prevent it from being aromatic?
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Charlie
#6 posted 03-26-2012 04:38 PM
Pretty much, yeah. I just went and smelled some of my older flutes… heheheh…. ok that sounded weird even to me…. and I can still smell the cedar, but also the tung oil. The ones that were waxed, I can’t really smell the cedar any more. I have 2 that were poly’ed (gifted to me) and you can’t smell the cedar at all on those. BUT, the poly’ed ones retained color better than any of the others I think. I say, “I think” because different batches of blanks have different coloring and I might be comparing to some that started out less red… shrug
