Drill Stand for Fein Multimaster
Forum topic by fireclaw posted 03-26-2012 04:32 AM 3729 views 0 times favorited 0 replies Add to Favorites Watch
View fireclaw's profile
fireclaw
1 post in 3664 days
03-26-2012 04:32 AM
I have had a Fein Multimaster for many years and I continue to find new ways to use it. I have recently purchased the Fein tool stand. It allows you to mount it to a bench so the tool is stationary or “clamped to commercially available drill stands with a 43 mm collar diameter”.
http://www.google.com/products/catalog?hl=en&pwst=1&rls=com.microsoft:en-us&q=fein+tool+stand&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1440&bih=731&wrapid=tlif133273496490810&um=1&ie=UTF-8&tbm=shop&cid=16475148721344897882&sa=X&ei=-OtvT4qGLomvgwekkeFr&ved=0CKwBEPMCMAY#
The trouble is I cannot find a tool stand that looks worth the money. I have found two Bosch drill stands for $280-350. They looks very solid and well build, however more that I care to spend.
I have found a full range of others from China; they are any where from $30 to $100. Some are obviously cheap, while others look like they may work. However I am skeptical and there is little information is available on these.
I did find one made in Germany for about $90, but the shipping would be about $90 also. I cannot find a US outlet.
http://www.fine-tools.com/bohrstaender.html
Ok, enough whining, has any one out there mounted their multimaster to a drill stand, and if so, what brand and where did you get it?
Thanks for your advice.
Dennis
0 replies so far
