Holding little work
« back to Hand Tools forum
Forum topic by TNWoodwright posted 03-25-2012 11:02 PM 1099 views 0 times favorited 9 replies Add to Favorites Watch
View TNWoodwright's profile
TNWoodwright
25 posts in 3653 days
03-25-2012 11:02 PM
Lots of info lately on workbenches and vises et-al But I have a bunch of jewelry boxes to build and other small boxes down to 1-1/2 inch. I need some ideas to hold this stuff while running grooves for bottoms and drawer runner sides. Also for molding edges. I try to use a larger piece to cut up later but would still be interested in what others do. A lot different than making a big cabinet :)
Thanks
-- If you have a garden, a shop and a library, you have everything you need with apologies to Marcus Tullius Cicero
9 replies so far
View William's profile
William
9950 posts in 3082 days
#1 posted 03-26-2012 02:28 AM
Anything too small for me to hold safely, I use wooden clamps.
These kind.
View NBeener's profile
NBeener
4816 posts in 3414 days
#2 posted 03-26-2012 02:39 AM
Me, too.
Somebody makes/sells a small parts routing jig, or gizmo, but … handscrew clamps are really workable.
-- -- Neil
William
#3 posted 03-26-2012 02:41 AM
I had a small parts thingy from Kreg once Beener.
After having too many small parts fly though, I threw it in the trash and went back to my wooden clamps.
TNWoodwright
#4 posted 03-26-2012 02:50 AM
How do work a plane with those. I have them but were talkin layin 1/2 in stuff flat and puttin a dado in it for bottom or on the side for a runner. And what if you want to mold n edge. Something like a shooting board :)
William
#5 posted 03-26-2012 02:57 AM
I’m sorry. I thought you meant like to work on a router table. I use mostly power tools.
If I’m running small stock through my power planer, I use two sided tape to attach it to a larger board and take tiny passes.
Molding, edging, dados, and such, I hold it with the clamps like I showed above and use my table saw or router on the router table. If it’s too large for my largest clamp, then I feel it’s large enough I can safely handle it with push sticks or my hands.
I am not much help though if you’re talking about holding it for hand tool work. I imagine you could build a small vise though.
View Viking's profile
Viking
880 posts in 3435 days
#6 posted 03-26-2012 03:07 AM
Agree with William and Neil above. Clamps work very well and most of the small parts holders are just pricey derivative of simple hand screw.
Perhaps instead a planing, how about a belt sander, still holding parts with a clamp, etc. ??
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View SteveMI's profile
SteveMI
1128 posts in 3534 days
#7 posted 03-26-2012 03:16 AM
I try to cut everything while the wood is in it largest form. Sometimes it seems dumb, but it makes a safer process. Such as cutting the rabbet or dado for the box bottom and lid before cutting the board to the lengths of the sides. Since I do 45 degree corners, I can round all the edges while the board is full length also. Some designs you can’t do that.
Like William said, double sided turners tape can attach the smaller parts to a larger one for cutting. Bit of a pain to separate parts sometimes though.
Steve.
TNWoodwright
#8 posted 03-26-2012 04:08 AM
I understand where you guys are coming from but I’m talking 17th and 18th century stuff here :) Trying to figure out how they did it back then. :) Gotta be a way to hold small work without all these here modern conveniences :)
View woodtools's profile
woodtools
21 posts in 2529 days
#9 posted 03-26-2012 04:44 AM
In the early days they used a holdfast. Usually custom made by the local blacksmith. Very functional and, by their name, holdfast…....
Hope this helps :-)
