Workshop in progress
Forum topic by Slacker posted 174 days ago 270 views 0 times favorited 7 replies Add to Favorites
View Slacker's profile
Slacker
174 posts in 238 days
174 days ago
Since moving from an apartment to a real house, I have been able to build up a workshop that I feel comfortable in. I started a few months ago with a little workbench attached to the wall which I could swing up to a flat against the wall position, and a board with holes in which to hang my screwdrivers and stuff.
Then I got a miter saw, and to “test” the miter saw, I built a bench. Things are coming along.
Then I got a table saw and re-discovered that you really need an outfeed table. At about that time, I discovered the newfangled workbench, and I done seen the light. And since I was going to build the newfangled workbench, may as well build a wall-hung tool cabinet (like the one Norm made).
First I built the wall-hung tool cabinet. Not quite finished, but very functional. Going to glue metal sheets to the outside of the doors with a simple frame to use magnets.
Then I cut the legs on the workbench so that it would fit as an outfeed table for the table saw.
And I am almost finished with the newfangled workbench, which was one of the funnest things I have built, even though it was really, really hot here, and you had to concentrate to keep the piece on track.
And, for no particular reason, I built a condo vac…
And after all that trouble, my landlord has decided that he wants to sell the house, so I have to get out of here by the end of June. Hmmm, new house, blank slate, I can deal with that.
-- There are three kinds of people... those who can count, and those who can't
View Betsy's profile
Betsy
1886 posts in 433 days
174 days ago
Doesn’t sound like you’re a “slacker” to me. Sounds like you’ve been busy and will be busier still. Good luck getting to a new house. Of course, the way the housing market is, you may not have to worry about moving anytime soon.
-- Betsy - GO BUCKS!
9878 posts in 359 days
173 days ago
You certainly have been busy. In your next house I hope you can find the space to continue your shop building exercise.
Good luck.
View Rymann's profile
Rymann
11 posts in 314 days
173 days ago
Wow! I really want to see a closer shot of the surf board rack…that’s what I need.
Slacker
173 days ago
The surfboard rack is just two 2×4’s hung vertically, I think the separation is 48”. I drilled in a hole every 10 inches or so (enough space to clear the fins from one board to the other), one inch diameter, at a slight angle and inserted one-inch dowels.
View Al Killian's profile
Al Killian
210 posts in 290 days
173 days ago
Moveing and haveing to start from stracth can be great, but time consuming. I have, for the last few month have been trying to get my shop finished. Take your time and keep us updated.
Slacker
173 days ago
Just hanging around the house thinking of packing and moving and how unfun that would be, I decided to do something useful that I had been thinking about. So I cut some long strips with a triangular cross section and glued and stapled them to the underside of the well covers on the newfangled bench.
Now, if I wanted to paint something, I can turn the well covers around (triangle strips facing up), put the piece on the strips, and be able to control paint runoffs a little better. I dont know if these triangles have a name, but I think they will work real well.
View Mark Shymanski's profile
Mark Shymanski
715 posts in 249 days
167 days ago
Just noticed your signature line… very funny…it took me an embarassinlgy long time to get the joke, wonder which group that puts me in :-)
-- ....next big purchase is wood for the next project, Mark
Bookmark And Share This Page
