Earlex 5500
Forum topic by Estley posted 03-24-2012 07:04 PM 1425 views 0 times favorited 1 reply Add to Favorites Watch
View Estley's profile
Estley
66 posts in 3656 days
03-24-2012 07:04 PM
Topic tags/keywords: spray gun
So I’ve decided to take the plunge into an HVLP system, and for my budget/needs the Earlex looks perfect. So, Everybody says to get the fine needle (I think I’ll use it mostly for water based poly), is it worth getting the “ultra fine” as well?
1 reply so far
View ducky911's profile
ducky911
237 posts in 2661 days
#1 posted 03-25-2012 05:45 PM
I have the 5000 and been thinking to up grade as i would like to spray latex without so much thining. I mix poly in with the paint along with water and festol. The instructions say thin form 35 to 60 sec. I thin to 35 and bought the 2.5 tip…and can get prettygood results.
Your 5500 is better and with poly i use the 1.5 or 2 tip.
Earlex blows air all the time when on. Even when you are not pulling the trigger. It ok but be carefull not to blow dust around when pointing off the target.
It simple to use and cleans up easy
