Predrilling When Using Pocket Hole Joinery
Forum topic by jstewart posted 123 days ago 240 views 0 times favorited 10 replies Add to Favorites
View jstewart's profile
jstewart
137 posts in 577 days
123 days ago
Topic tags/keywords: pocket hole kreg predrilling question
I think I’ll try using pocket hole joinery for one of my next projects. After looking at all of the various Kreg systems out there (and a few other brands) I still have one question. When drilling the pocket holes, do I also need to predrill in the adjoining board? Will the self tapping screws do all the work for me? I’m going to be working with red oak. I’m sure in pine I could get away with more than in a hardwood.
Any helpful thoughts are appreciated.
-- Joshua, Olathe, Kansas
View Betsy's profile
Betsy
1779 posts in 382 days
123 days ago
Just use the right screws and no predrilling is necessary. That’s one of the beauties of the screws.
-- Betsy - GO BUCKS!
View bhack's profile
bhack
118 posts in 206 days
123 days ago
Joshua,
The self tapping does all the work. Just be sure to have the butt joint tight when driving the screw and it will be a very strong joint.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
View Randy Sharp's profile
Randy Sharp
99 posts in 158 days
123 days ago
Right Betsy. Course-thread screws for softwood, fine-thread screws for hardwood.
-- Randy, Tupelo, MS ~ May I become more like the Master Carpenter every day.
View Loren's profile
180 posts in 134 days
123 days ago
Use the self-tapping screws.
I prefer the Kreg screws. I bought some generic ones
a while back and the specs are a little different… caused
problems.
If you are joining face frames be careful, especially in hard
hardwoods. In some cases you might want to leave a
“horn” on the rail or stile that you trim off after putting
the screws in. If your screw is close to the end of a board
sometimes splitting will occur. The joint is still strong
but the split is ugly.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online business building
View blackcherry's profile
blackcherry
196 posts in 309 days
123 days ago
As Randy stated Course tread for softwoods and Fine treads for hard woods. I use a dap of glue as well just for added stength. Blkcherry
View Huckleberry's profile
Huckleberry
64 posts in 339 days
123 days ago
As for your question on red oak, I have used them a lot on red oak and have not really had many issues with it. And as Black cherry said a little glue and its a real good joint.
-- Something that goes unnoticed will never be remembered.
View Yettiman's profile
Yettiman
117 posts in 224 days
123 days ago
Hi,
I’ve used Pocket screws quite a few times and it’s all good advice here.
Official Kreg screws are more expensive, but they are worth it, and do clamp tight before you screw together, this is most important. I have found that the screws hold the joint well, but they do not pull the joint tight, so clamp it tight first and all is well
-- Keep your tools sharp, your mind sharper and the coffee hot
jstewart
123 days ago
Thanks to all of you for your pocket hole advice. Now I just have to decide which Kreg system to buy. I don’t think the little one-hole jig is going to be what I want since my next project will have about 24 different places where I want side-by-side pocket holes. I’m thinking about shelling out for the Master System (especially since I would get a free right angle clamp through a current Amazon promotion) at $139 or maybe just the Standard Pack at $75. Perhaps the R3 at $40 would be good enough, but I would still have to buy a face clamp.
View GaryK's profile
GaryK
8486 posts in 474 days
123 days ago
Looks like you got all the answers you need.
5675 posts in 337 days
123 days ago
Josh, the pocket hole screws provide a very effective joint using the right screws. You do have the disadvantage of having the screw holes showing, but if they are in a hidden place there is no problem.
Bookmark And Share This Page
