| Forum topic by Beginningwoodworker | posted 124 days ago | 297 views | 0 times favorited | 14 replies | ![]() |
124 days ago |
I have a question now I have a 10×12 small shop, are there some tools that I can get by without and still do good woodworking? my dream tools are Jet proshop table saw, a makita thickness planer, and vs small protable tools that I need. a 6’’ jointer and a 14’’ bandsaw is on my list of tools. but maybe I can do without those. -- CJIII Future cabinetmaker |
124 days ago |
A 14” bandsaw will take up about a 1/4 of your shop, same problem the table saw. You need to think of the mantra, it’s a poor craftsman who blames his tools. Think Jointer Plane instead of Jointer. 12” Bandsaw at the largest. I know everyone loves to show off their latest tools, but the bigger/badder tools don’t allow you to work wood that much better, its the skill that you have that allows it. |
124 days ago |
I agree with Marc. I don’t own a jointer or a planer, my band saw is a 9” Delta, and my table saw is a $99 Ryobi. I think I turn out some fairly respectable stuff with limited equipment. Having said that, I do have plans to upgrade and get more tools into my tiny shop as finances allow. I think the key to a small shop is mobile bases. You’ll never be able to set up a full array of stationary tools in a 10×12 shop, but if you have most of them set up to where you can roll them out of the way when not in use, I think you can do a lot with a small space. -- Charlie M. "Woodworking - patience = firewood" |
124 days ago |
I have hand planes. so the jointer problem is solve. I got a no 8 jointer plane, and I have a scurb plane that can take the cup out of board, I guess a good Bosch Jigsaw solve the bandsaw problem I am just looking to cut curves anyway, The table saw is going to have to fit, I just got rid of my cheap benchtop table saw because it was to little. -- CJIII Future cabinetmaker |
124 days ago |
Great, you’re 1/2 way there. Now you can probably get the saw in place. Fine Woodworking put out a little book a while ago about shop storage tips. One of the shops featured was a small garage ment to house a Model-T car, I think it was about your size. You should see if you could find it. |
124 days ago |
My first shop was a (barely) one car bay garage. I had a six” jointer (which I’ve since parted ways with), a 14” band saw, a craftsman table saw, bench top planer, Jet dust collector, drill press and a small lathe. I managed to make an entire bedroom suit out of that little space. Charlie’s right——- mobile bases are the way to go. In a small shop, organization is everything. Good luck! -- Betsy - GO BUCKS! |
124 days ago |
I’ve got a teeny little shop, and I’ve gone the Festool route in it, with a DeWalt 735 benchtop planer on a moble table that I wheel out of the way most of the time (I’d have skipped the table, but my sweety insisted that it not be a “lift it on, lift it off” situation). The router table hangs off the Festool MFT table, and on the wall when it’s not in use. I use the circular saw on the rail instead of a table saw or jointer, I’d love a bandsaw for resawing, but for now get along with other techniques. There’s stuff I can’t do, and some rips are a little harder with the saw and rail than they would be on a table saw, but as marcb noted, those of us with one car garages built in the 1940s have to make compromises. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
124 days ago |
like said above the key is mobile based, storage, and multi functioning. making things like a mobile table saw station with a router table is a great way to take up space because the fence rails would have taken up the space where the router table was, a roll around assembly table can double as an outfeed table, and if you really want a jointer and planer you might want to thing about a combo unit. i know that Jet has a comb 12” jointer and planer in one machine, if you put that on a mobile base you’re good to go. hope that helps. |
124 days ago |
If I could have just one machine it would be a band saw In my early days I flattened a lot of boards by hand. A 12” or even 10” bandsaw is actually fine. A lot of the For plywood cutting I would go with a circular saw and I think the table saw is over-rated for anything but cabinet -- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online business building |
124 days ago |
hi all like a lot of people here my single car garage ( small car) is my work shop i have a dewalt planer thickner which sits under my work bench when not in use if i need my tablesaw that has to be rolled outside i like you would love a bandsaw but space is tight so not just yet but saying all that i love MY SPACE and at least we know were everything is lol (sort of) -- cut it saw it scrap it |
124 days ago |
for small spaces check out tools that do more than one thing, for example mini max makes a very nice jointer/planer/horizontal mortiser, that would fit perfectly in a one car garage. surf the web and you’ll fing cool stuff like that.and just to tell you we use this tool at school and it works very well. -- Roper - master of sawdust- |
124 days ago |
I noticed that you left out a router or two. With a little creativity, a router is an extremely versatile tool. I’ve made a variety of jigs to help trim boards to length, run dadoes and rabbets, and even shape curves. If you have a tablesaw, a jigsaw, a router with a handful of bits, some chisels and handplanes there isn’t much you can’t do. All the above mentioned tools are great multi-taskers. Small shops demand multi-tasking tools and mobile bases. A decent grinder to keep those hand tools in shape would be a good addition too. Good luck. -- Chuck Bender, period furniture maker, www.acanthus.com |
124 days ago |
If you have outside space you can use you could go for for a lightweight portable table saw or mitre saw. Bandsaws don’t take up as much room but you do need the space around them to get the best use from it. -- Grumpy - "Always look on the bright side of life"- Monty Python |
124 days ago |
I got a router Chuck I am going to get another one. -- CJIII Future cabinetmaker |
123 days ago |
To Loren’s comment, Makita has apparently come out with a Festool knock-off, now that some of Festool’s patents on the plunge saw have expired, so you might look at that. Here are some comments I made in another thread about things I'd look for in saw-on-rail systems. However, the other thing Loren mentioned that I wanted to address is price. As I said in that thread, yes, the tool costs can seem pricey, but be sure you consider them as capital costs in relation to your materials. I’m just a hobbyist playing around with projects for the house, and most of the lumber I’m working with is scrap or reclaimed and seems to cost me circa $2/bf, but even having bought a Domino and a planer, this year I’m going neck and neck between lumber and tools. We’re about to blow that back towards the tool side with a grand or so upgrading our router table setup (PC7518 + lift, and a couple of bits that run about a Franklin a piece), but if we finish the kitchen cabinets before the end of the summer I can see going back and spending more on wood. And if we start counting things like slides and hinges there’s at least another $600, so we probably will end up this year, our second doing woodworking worthy of the name, having spent about the same on tools and materials. So even if you’re “just” a hobbyist, take a real look at what you’ll be spending everywhere. For me, when I started looking at a couple of thousand bucks a year on materials, all of a sudden the high end tools didn’t look that scary. (I’ve got a friend who’s got a nice little side table that’s got about $700 worth of wood in it. If I were buying the super-exotics, rather than just scraps of Maple, Mahogany, Massaranduba and Ipe, then one or two screw-ups would pay for a better router system right there…) Of course if you’re actually aware of what your woodworking will cost you may also end up sticking to a whittling knife and firewood, and I wouldn’t blame you there either. Grin. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1228 |
1660 |
120 |
336 |
103 |
Woodworking Trade & Swap
233 |
Coffee Lounge
928 |
LumberJocks.com Site Feedback
269 |
