Cutting a rabbet on a beveled edge
Forum topic by DanRJ posted 420 days ago 536 views 0 times favorited 5 replies Add to Favorites Watch
View DanRJ's profile
DanRJ
7 posts in 568 days
420 days ago
Hi everyone,
I’m looking for some help on how to cut a rabbet on a beveled edge. I did a quick drawing in Paint to help you visualize this (I hope it shows up ok). The tools I have to work with are a handheld router and table saw. I was thinking I could continue to use the table saw still set at a 45 bevel to cut the rabbet but that it would be difficult to get the proper depth since it would be varying. Is there a way to do this with a handheld router? If anyone has any great tips I would really appreciate it. Thanks for everyone’s help! I really enjoy this website for all the help!
Dan
5 replies so far
View BlankMan's profile
BlankMan
1487 posts in 1518 days
#1 posted 420 days ago
I’m thinking the safest way may be using a jig that supports it on that angle and held in place by clamps, the jig riding in the miter slot on the table saw or on a router table.
-- -Curt, Milwaukee, WI
BlankMan
#2 posted 420 days ago
That was thinking that it was small piece(s) you had to do. If it’s a big wide piece you could lay it flat on the table saw and have the dado on a 45 and run the board along the fence. I’d suggest using scrap pieces to try it and get it set up to where you need it.
I’m a little concerned though, if it’s big and it cocks when you’re running it through it could pinch and have a kickback situation. I’d be tempted to do it on my Unisaw that is stable and has a solid fence but maybe a little leery on a table saw that might be considered flimsy.
View canadianchips's profile
canadianchips
1773 posts in 1162 days
#3 posted 420 days ago
I would use my table saw.
BlankMan
#4 posted 420 days ago
I guess I was assuming he had a dado set and could do it flat and cut the rabbit in one pass. Cut the 45 then cut the rabbit with the dado. Didn’t think everybody may not have everything. :-)
DanRJ
7 posts in 568 days
#5 posted 420 days ago
Thanks for the tips!
