Cauls for panel gluing ?
Forum topic by MrWoody posted 87 days ago 337 views 0 times favorited 12 replies Add to Favorites
View MrWoody's profile
MrWoody
186 posts in 224 days
87 days ago
Topic tags/keywords: question gluing panels cauls
I borrowed some cauls for gluing up some panels and they work but I think they could work better.
There is no crown on top or bottom piece. I think they should have a slight crown on one of the pieces.
How much crown on say 30” cauls ? How do you create it ? Would several coats of poly be enough to stop glue from sticking to them ?
-- If we learn from our mistakes, I'm getting a fantastic education.
3976 posts in 668 days
87 days ago
This may be a very low-tech response, but I use whatever scraps I happen to have laying around when I need cauls to glue up a panel.
As far as the glue issue, I just put a folded piece of waxed paper between panel and caul.
8557 posts in 271 days
87 days ago
Here is a response for a similar question that Marc Spagnolo sent out today via e-mail:
How To Make Cauls? – Question of the Week
Posted: 09 Jun 2008 07:49 PM CDT
This week’s question comes from Geoff. He writes:
I have a question about cauls and how to make them. I have made some small ones (about 24″) out of some 2x pine. They did the job of gluing up a small table top, but… I want to make a real “set” of them but I don’t know what to make them out of. Could I laminate 1/4″ ply (I have a lot of scrap!) over a curved form to create a slight camber or should they be made out of maple or another hardwood? Thanks for the help and keep up the great work!
And here was my response:
Here’s the great thing about cauls Geoff. They can be made out of just about anything. I have a little bucket that I keep behind my bench that is full of little scraps of wood of all shapes and sizes. But they are really just scraps. Nothing made specifically for that purpose. The only time I specifically make cauls is when there is a very special clamping situation. And usually I use them for that task and wind up losing them a few weeks later.
So I use everything from plywood to solid wood scraps of all species. If you are making a really nice set, you probably can’t go wrong with oak or maple. Poplar would be a fine choice too, as would plywood (if done correctly). If you make a cambered caul out of 1/4″ ply, like you mentioned, you’ll need quite a few strips before the sandwich is sufficiently resistant to bending. You want enough resistance so that the crown of the camber provides the appropriate amount of pressure. You might have more luck using solid wood, but the ply is certainly worth a shot.
  • For those who don’t know, a cambered caul is simply a caul that has a curve in it. These are most useful when clamping long surfaces where you can’t get clamping pressure in the middle of the joint. The best example I can think of is clamping a bookshelf into a dado in the side of the case. The crown of the cambered caul goes on the center of the joint and the ends get clamped down. This applies the needed pressure all the way across the joint. The trick, is figuring out how much of a curve to put into the caul in the first place.
View Bigbuck's profile
Bigbuck
820 posts in 112 days
87 days ago
I put a few coats of polly on mine and then a put a stip of painters tape on the faces that come into contact with the panel. So far this seems to work pretty good.
-- Glenn, New Mexico
MrWoody
87 days ago
Charlie, Scott, (Marc), I would ususally use scraps, but I quite honestly don’t have any scraps here suitable to use. That is why I had to borrow some. :^)
The last few projects have been toys, therefore, scraps gone.
I decided that if I had to buy wood to make cauls, I may as well do it right. That way I won’t get caught without, again.
I think as far as crown goes, I’ll try 1/16th each end from centre.
Thank you all for your replies.
View VTWoody's profile
VTWoody
95 posts in 506 days
86 days ago
Clear packing tape is a good solution to keeping the glue from sticking.
View Al Killian's profile
Al Killian
178 posts in 202 days
86 days ago
I have some cuals that I bought and the work great. A fellow woodworker on a different forum makes them. Here is the link to his site http://www.bowclamp.com/. I have used them for pressing veneer on to a dresser and had exellent resulsts.
For keeping the glue from sticking use wax paper.
View GaryK's profile
GaryK
8410 posts in 437 days
86 days ago
I just do like Charlie.
View Doug S.'s profile
Doug S.
161 posts in 157 days
86 days ago
Another vote for the BowClamp cauls. They work great.
-- Use the fence Luke
View bbqking's profile
bbqking
190 posts in 173 days
86 days ago
I have a set of cauls that came from Charlie & Gary’s place. Keep an eye out and when you have a number of similar sized dropoffs from good, thick, ripped stock that will hold up to clamping tabletops & etc., Keep them and use them for that. More than several times I’ve had customers ask what those “boards” are for under my glueup table. I’ve had some of them for years. bbqKing
-- bbqKing, Lawrenceville
View beaudex's profile
beaudex
41 posts in 88 days
84 days ago
I must admit I use cauls routinely, mine are about 30 inches long and are crowned to about 1/16” on either end. They are made from 2×2 maple stock that I got at the sawmill as junk wood. When I first started using them I never thought that squaring them perfectly would critical however after a few uses I found out that taking the time to square them up made a huge difference. As far as glue goes the packing tape sounds like a great idea. I happen to have a doctor friend who gets me rolls of the table paper they use on the examining table that I use for my glue ups.
-- Derek Tay, Venerate the Tree Design
View Jim Crockett's profile
Jim Crockett
93 posts in 182 days
83 days ago
A question on cauls – I see many references to cambered cauls but don’t have a bandsaw so can’t figure out how to make them. I sometimes use a thin shim in the middle of the length of the caul – doesn’t this serve the same purpose as the cambered caul?
beaudex
41 posts in 88 days
80 days ago
Jim,
I just hand planed my caul’s to camber them.
Derek
Bookmark And Share This Page
